Does this sound like a wheel bearing? #1944190
11/03/15 02:16 AM
11/03/15 02:16 AM
PA
Big Mike Offline OP
Big Mike  Offline OP
PA
Re: Cant figure out front end noise [Re: Big Mike] #1944217
11/03/15 02:58 AM
11/03/15 02:58 AM
md
mopars4ever Offline
mopars4ever  Offline
md
are you sure it is coming from the front end? I had noises that sounded like it was coming from the front but it ended up being my rear u joint.
Re: Cant figure out front end noise [Re: Big Mike] #1944275
11/03/15 10:03 AM
11/03/15 10:03 AM
PA
Big Mike Offline OP
Big Mike  Offline OP
PA
When driving it's high squealing metal on metal sound.
Re: Cant figure out front end noise [Re: Big Mike] #1947067
11/07/15 06:40 PM
11/07/15 06:40 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Hard to tell ck shield rubbing rotor also ck the anti rattle clips rubbing the rotors. Bearing rarely make a high pitch noise. BTW rotor surface looks odd does the truck sit alot?
Re: Cant figure out front end noise [Re: Big Mike] #1947305
11/08/15 12:24 AM
11/08/15 12:24 AM
PA
Big Mike Offline OP
Big Mike  Offline OP
PA
It was the bearing. That thing was shot. Put a new hub on today and it's like day and night. Let's tell you. That hub was a [censored] to get out of the spindle. Had to beat the piss out of it. So much corrosion. Took a whole but finally got it.
