Power brake booster rebuilders,,
#1943926
11/02/15 09:11 PM
11/02/15 09:11 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Saw on here sometime ago, a member that rebuilt power brake boosters. Who was it,,or who do the masses recommend??? I have a friend that is restoring a '71 Charger SuperBee that needs one rebuilt..Thanks.
If you like drag racing, support your local track.
Re: Power brake booster rebuilders,,
[Re: CHAPPER]
#1943927
11/02/15 09:14 PM
11/02/15 09:14 PM
moparpollack
Lil Herman
Lil Herman
85086
Booster Dewey or Federal thru Rock Auto
[Re: Morty426]
#1944443
11/03/15 04:27 PM
11/03/15 04:27 PM
CHAPPER
Belpre,Ohio
71 booster is pretty simple - you can probably restore it yourself if its just in need of cosmetics It needs the full resto,,,inside/outside.
[Re: CHAPPER]
#1944871
11/04/15 06:43 AM
11/04/15 06:43 AM
Posts: 2,592 None
71rm23
None
71 booster is pretty simple - you can probably restore it yourself if its just in need of cosmetics It needs the full resto,,,inside/outside. Dewey did mine. Turned out good!. For some reason, can't post picture
[Re: 69Boss302]
#1949211
11/11/15 02:48 AM
11/11/15 02:48 AM
Posts: 5,796 minnarusta
TX9H6E4CUDA
minnarusta
If you use Booster Dewey make sure to stamp your booster and them take a picture of it. I have sent- -on more than one occasion- -super nice cores only to get back someone elses pitted booster instead of the one I sent. He did send another booster but they were never as nice as the cores I sent plus the pain of messing with it without any compensation. He does great work other than that! I was wondering if I was the only one. I sent him my non pitted core and got back a pitted one back with cad plating that is turning white (because of the corrosion in the pits). Otherwise the booster works awesome.
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
