Springs needed for Eddie heads? #194410
01/15/09 03:00 PM
01/15/09 03:00 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
I need to replace the springs on my small block heads. Oringanly I had a cam ground to meet the max I could with what came with the.
Back then I had the spects on the springs.
Long story short the heads sat in water for over 2 weeks under my water ned anlong with a 1000buck 44 mag.
I was dumm when I gutted the home and cut the carpet around the bed and later found them under it,.
The Machinest says the seats need cleaning up and new springs. should I go haed and get retainers as well?
So I need spects on what to get as well as Best source for new springs? Summit/Jegs just call Engle
Engle Cam spects are
Vavle lift/ Running duration / Vavle Lash / Duration @ .050
IN 560 / 275 / 018 / 244
EX 575 / 284 / 020 / 252
It is a soild cam for a 340 stroker ground on 110
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Springs needed for Eddie heads? [Re: 340SIX] #194411
01/15/09 03:12 PM
01/15/09 03:12 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
hughes 1111
comp 987
both have an install height of 1.80..
the hughes has a little more seat pressure..
Tony
70 AARCuda Vitamin C
Re: Springs needed for Eddie heads? [Re: 70AARcuda] #194412
01/15/09 03:15 PM
01/15/09 03:15 PM
340SIX Offline OP
340SIX  Offline OP
If I get new retainers will it matter what locks I have?
Re: Springs needed for Eddie heads? [Re: 340SIX] #194413
01/15/09 03:18 PM
01/15/09 03:18 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
eddy have 11/32 stems...your retainers and locks need to match the valve stem diameter.
the hughes 1111 springs fit the eddy retainers..as i swapped out a set a couple of weeks ago...
Tony
Re: Springs needed for Eddie heads? [Re: 70AARcuda] #194414
01/15/09 03:27 PM
01/15/09 03:27 PM
340SIX Offline OP
340SIX  Offline OP
http://store.summitracing.com/partdetail.asp?part=CCA%2D987%2D16&view=8192&N=700+
I may not need the locks only one head looks bad it was sitting onto the other. It might pass but not worth taking the chance
