I need to replace the springs on my small block heads. Oringanly I had a cam ground to meet the max I could with what came with the.
Back then I had the spects on the springs.
Long story short the heads sat in water for over 2 weeks under my water ned anlong with a 1000buck 44 mag.
I was dumm when I gutted the home and cut the carpet around the bed and later found them under it,.
The Machinest says the seats need cleaning up and new springs. should I go haed and get retainers as well?
So I need spects on what to get as well as Best source for new springs? Summit/Jegs just call Engle Engle Cam spects are
Vavle lift/ Running duration / Vavle Lash / Duration @ .050
IN 560 / 275 / 018 / 244
EX 575 / 284 / 020 / 252
It is a soild cam for a 340 stroker ground on 110
