73 Barracuda race car weight #1944052
11/02/15 11:51 PM
11/02/15 11:51 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Toying with the idea of using my 73 barracuda for a race car. I don't want to cut the car up so as to be non streetable in the future (I was doing the pro-street thing) I have taken the guard beams out of the doors but the windows will stay. I guess set up like a stocker is the way I'm thinking. No wipers or heater,racing seats,striped out dash. Been tubbed, frames connected, roll bar, fuel cell. Glass hood, cal-trac Dana. You guys that have cars like this, how much do they weigh? How light can they be? Can I get it down to around 3000 lbs? I can do SB or BB auto. Any info or direction would be helpful.
Re: 73 Barracuda race car weight [Re: cudaman1969] #1944079
11/03/15 12:19 AM
11/03/15 12:19 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Stripped down, steel body, 6 point, frame connectors, tubs, glass hood, SS springs, 440, Hemi box & scattershield, Dana, my 'Cuda weighed 3150 ready to race.
[image][/image]
Re: 73 Barracuda race car weight [Re: cudaman1969] #1944095
11/03/15 12:32 AM
11/03/15 12:32 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
my 72 is 3132 without me, full dash, interior, subframes and 4 point bar, it does have a pin on glass hood. back braced 8 3/4 not tubbed, all factory glass, carpet etc.
Re: 73 Barracuda race car weight [Re: upnover] #1944124
11/03/15 12:59 AM
11/03/15 12:59 AM
fredericksburg,va
fredericksburg,va
You say "interior" that mean factory seats,front and back?
What engine?
Re: 73 Barracuda race car weight [Re: cudaman1969] #1944140
11/03/15 01:15 AM
11/03/15 01:15 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
racing seats in the front, factory rear seat, factory dash, console, carpet, headliner, sunvisors. 512 bb based on a 400, alum heads, water pump, water pump housing etc. ive had to work hard to get it that light but it can be done.
Re: 73 Barracuda race car weight [Re: cudaman1969] #1944246
11/03/15 04:45 AM
11/03/15 04:45 AM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
The wife's 73. Full interior, no heater, 512 BB/727, 83/4, driver and, spare tire, 3475 lbs 11.50 street car. She won't let me tune the engine because she will not put a bar in the car.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: 73 Barracuda race car weight [Re: Digger73] #1944441
11/03/15 04:24 PM
11/03/15 04:24 PM
fredericksburg,va
fredericksburg,va
Digger73 (Mike)
Looks good, my color. radial tire? Suspension?
Re: 73 Barracuda race car weight [Re: cudaman1969] #1944448
11/03/15 04:37 PM
11/03/15 04:37 PM
fredericksburg,va
fredericksburg,va
Weighted some componites last nite. K-frame-40 lbs, complete hub-disc-caliper,upper and lower arms-75 lbs each side. Doors with nothing in them 58 lbs, window and remaining door parts 40 lbs. didn't weight fenders yet but I'm guessing 40-60 lbs. optimistic about losing a bit of weight off the car without changing its integrity. Thanks for all the input so far folks, very helpful.
Re: 73 Barracuda race car weight [Re: cudaman1969] #1944472
11/03/15 05:31 PM
11/03/15 05:31 PM
sst404b Offline
sst404b  Offline
Our 73 Challenger stocker we raced in G the min.wt.is 3525 at the last race it weighed 3660. We took the car apart last week and all the ballast was 410 lb so race ready with 210 lb driver would be 3250 3040 w/o driver. Car had all light weight stuff,wheels,brakes,rear ect. but had production seats front and rear and complete doors and dash. Check out Buckner Boys Racing on facebook for pictures
Ray Buckner
Re: 73 Barracuda race car weight [Re: cudaman1969] #1944475
11/03/15 05:37 PM
11/03/15 05:37 PM
an8sec70cuda Offline
My '70 cuda is about 3600# w/o driver. It's a tank.
The only weight reduction is aluminum wheels, Aerospace front disc brakes, a fiberglass hood (a heavy bolt on), and I removed the heater box.
ALL factory interior is in place, nothing cut out, and it has a 10 point cage.
Manual steering and brakes, 727 trans, Dana on leaf springs, and an all aluminum hemi (weighs the same as an iron block aluminum head 440).
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 73 Barracuda race car weight [Re: cudaman1969] #1944544
11/03/15 08:34 PM
11/03/15 08:34 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
Digger73 (Mike)
Thanks for the compliment. The rears are Hoosier QT pros 27 x 11.5. The suspension is all stock up front and the rear is Mopar heavy duty leafs with Caltracks with air shocks.
The biggest weight savings we did was to remove the extremely heavy front bumper inner structure and the outer bumper mount bracket. we do have an aluminum radiator, water pump\housing and, aluminum brake master cylinder. We still have all the glass and regulators.
Digger73 (Mike)
Re: 73 Barracuda race car weight [Re: Digger73] #1944555
11/03/15 08:50 PM
11/03/15 08:50 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Mine was 3230lbs with an iron block Hemi...We now have an aluminum 605 Hemi.... Standard roll bar, race seats, no back seats, no wipers, no heater box, MF front k-frame, and FG hood, full carpeting....Dana 60 with a spool and leaf springs and Wilwoods on all corners...We are thnking one run in the mid 9's and then we slow it down to 10.0's...
Re: 73 Barracuda race car weight [Re: sgcuda] #1944655
11/03/15 11:15 PM
11/03/15 11:15 PM
fredericksburg,va
fredericksburg,va
What would the weight difference be between the four speed-bell and a auto?
Re: 73 Barracuda race car weight [Re: cudaman1969] #1944700
11/03/15 11:42 PM
11/03/15 11:42 PM
sgcuda Offline
sgcuda  Offline
I'd have to guess that the A/T would weigh 75 pounds less than a four speed set up. Closer to 100 pounds on mine, since I had a Lakewood shield.
[image][/image]
Re: 73 Barracuda race car weight [Re: sgcuda] #1944738
11/04/15 12:24 AM
11/04/15 12:24 AM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
73 Barracuda fiberglass fenders and hood steel bumpers and doors with stock glass 8 point cage racing buckets no defroster dana no tubs super stock springs small roller cammed 55 over 440 with cast iron -1s two optima batteries 3100lbs low 10.20s
Re: 73 Barracuda race car weight [Re: cudaman1969] #1944745
11/04/15 12:43 AM
11/04/15 12:43 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
motorhead446 on the board here is making me some aluminum bumper brackets front and rear for my 72, you might check with him
Re: 73 Barracuda race car weight [Re: evenflow] #1944855
11/04/15 04:26 AM
11/04/15 04:26 AM
fredericksburg,va
fredericksburg,va
3100, just car or you in it?
Re: 73 Barracuda race car weight [Re: upnover] #1944857
11/04/15 04:36 AM
11/04/15 04:36 AM
fredericksburg,va
fredericksburg,va
That's one of the things I've been looking at. Also aluminum door hinges,cross member, wing mounts instead of engine mounts, lighter steering column, brake pedal, all this stuff would add up quick. Free hp, well cheaper maybe.
Re: 73 Barracuda race car weight [Re: cudaman1969] #1944883
11/04/15 08:50 AM
11/04/15 08:50 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Mine 3350 give or take,had a few xtra bars installed sense the last time I weigh it sawzall weld anyway that's race weight stock body,glass hood,stock frame rails,tub back to the frame rails,BB with -1 heads,stock front suspension/ladder bars in the back.Best so far 9.40@142 wave
Re: 73 Barracuda race car weight [Re: racerx] #1945005
11/04/15 02:19 PM
11/04/15 02:19 PM
fredericksburg,va
fredericksburg,va
Are the e-body's aerodynamic at that mph and above? Anything needed as the mph goes up? Not saying I'll be in that territory, but who knows.
