73 Barracuda race car weight
#1944052
11/02/15 11:51 PM
11/02/15 11:51 PM
Posts: 8,325 fredericksburg,va
cudaman1969
fredericksburg,va
Toying with the idea of using my 73 barracuda for a race car. I don't want to cut the car up so as to be non streetable in the future (I was doing the pro-street thing) I have taken the guard beams out of the doors but the windows will stay. I guess set up like a stocker is the way I'm thinking. No wipers or heater,racing seats,striped out dash. Been tubbed, frames connected, roll bar, fuel cell. Glass hood, cal-trac Dana. You guys that have cars like this, how much do they weigh? How light can they be? Can I get it down to around 3000 lbs? I can do SB or BB auto. Any info or direction would be helpful.
Re: 73 Barracuda race car weight
[Re: cudaman1969]
#1944079
11/03/15 12:19 AM
11/03/15 12:19 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Stripped down, steel body, 6 point, frame connectors, tubs, glass hood, SS springs, 440, Hemi box & scattershield, Dana, my 'Cuda weighed 3150 ready to race.
[image][/image]
[Re: upnover]
#1944124
11/03/15 12:59 AM
11/03/15 12:59 AM
cudaman1969
fredericksburg,va
my 72 is 3132 without me, full dash, interior, subframes and 4 point bar, it does have a pin on glass hood. back braced 8 3/4 not tubbed, all factory glass, carpet etc. You say "interior" that mean factory seats,front and back? What engine?
[Re: cudaman1969]
#1944140
11/03/15 01:15 AM
11/03/15 01:15 AM
Posts: 1,837 tulsa ok
upnover
tulsa ok
racing seats in the front, factory rear seat, factory dash, console, carpet, headliner, sunvisors. 512 bb based on a 400, alum heads, water pump, water pump housing etc. ive had to work hard to get it that light but it can be done.
[Re: cudaman1969]
#1944246
11/03/15 04:45 AM
11/03/15 04:45 AM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
The wife's 73. Full interior, no heater, 512 BB/727, 83/4, driver and, spare tire, 3475 lbs 11.50 street car. She won't let me tune the engine because she will not put a bar in the car.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: Digger73]
#1944441
11/03/15 04:24 PM
11/03/15 04:24 PM
cudaman1969
fredericksburg,va
Digger73 (Mike) Looks good, my color. radial tire? Suspension?
[Re: cudaman1969]
#1944475
11/03/15 05:37 PM
11/03/15 05:37 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
My '70 cuda is about 3600# w/o driver. It's a tank. The only weight reduction is aluminum wheels, Aerospace front disc brakes, a fiberglass hood (a heavy bolt on), and I removed the heater box. ALL factory interior is in place, nothing cut out, and it has a 10 point cage. Manual steering and brakes, 727 trans, Dana on leaf springs, and an all aluminum hemi (weighs the same as an iron block aluminum head 440).
[Re: cudaman1969]
#1944544
11/03/15 08:34 PM
11/03/15 08:34 PM
Digger73
Portland, Oregon
Digger73 (Mike) Looks good, my color. radial tire? Suspension? Thanks for the compliment. The rears are Hoosier QT pros 27 x 11.5. The suspension is all stock up front and the rear is Mopar heavy duty leafs with Caltracks with air shocks. The biggest weight savings we did was to remove the extremely heavy front bumper inner structure and the outer bumper mount bracket. we do have an aluminum radiator, water pump\housing and, aluminum brake master cylinder. We still have all the glass and regulators. Digger73 (Mike)
[Re: Digger73]
#1944555
11/03/15 08:50 PM
11/03/15 08:50 PM
Posts: 12,408 Taxes & Virus's R-US, NY
Dragula
Mine was 3230lbs with an iron block Hemi...We now have an aluminum 605 Hemi.... Standard roll bar, race seats, no back seats, no wipers, no heater box, MF front k-frame, and FG hood, full carpeting....Dana 60 with a spool and leaf springs and Wilwoods on all corners...We are thnking one run in the mid 9's and then we slow it down to 10.0's...
[Re: sgcuda]
#1944655
11/03/15 11:15 PM
11/03/15 11:15 PM
cudaman1969
fredericksburg,va
Stripped down, steel body, 6 point, frame connectors, tubs, glass hood, SS springs, 440, Hemi box & scattershield, Dana, my 'Cuda weighed 3150 ready to race. What would the weight difference be between the four speed-bell and a auto?
[Re: evenflow]
#1944855
11/04/15 04:26 AM
11/04/15 04:26 AM
cudaman1969
fredericksburg,va
73 Barracuda fiberglass fenders and hood steel bumpers and doors with stock glass 8 point cage racing buckets no defroster dana no tubs super stock springs small roller cammed 55 over 440 with cast iron -1s two optima batteries 3100lbs low 10.20s 3100, just car or you in it?
[Re: upnover]
#1944857
11/04/15 04:36 AM
11/04/15 04:36 AM
cudaman1969
fredericksburg,va
motorhead446 on the board here is making me some aluminum bumper brackets front and rear for my 72, you might check with him That's one of the things I've been looking at. Also aluminum door hinges,cross member, wing mounts instead of engine mounts, lighter steering column, brake pedal, all this stuff would add up quick. Free hp, well cheaper maybe.
[Re: racerx]
#1945005
11/04/15 02:19 PM
11/04/15 02:19 PM
cudaman1969
fredericksburg,va
Mine 3350 give or take,had a few xtra bars installed sense the last time I weigh it anyway that's race weight stock body,glass hood,stock frame rails,tub back to the frame rails,BB with -1 heads,stock front suspension/ladder bars in the back.Best so far 9.40@142 Are the e-body's aerodynamic at that mph and above? Anything needed as the mph goes up? Not saying I'll be in that territory, but who knows.
