Re: 727 whines in reserve when cold
[Re: Steve88]
#1943728
11/02/15 03:52 PM
11/02/15 03:52 PM
Posts: 15,527 Omaha Ne
TJP
Omaha Ne
I usually let it warm up for a couple of minutes before I back out. I usually keep and eye on the temp gauge and wait for it to hit around 100 degrees before putting into reverse.
I did some searching on the internet and saw that some said that the fluid would drain out of the converter while sitting and putting the car in neutral for a few seconds would get the pump going and help out with issues like this. I just read that today so I havent had a chance to try it yet but I will give it shot this afternoon and see if that makes any difference. that is what is referred to as morning sickness, LOL, There is a fix for it but the Neutra thing works fine
[Re: Steve88]
#1944224
11/03/15 03:05 AM
11/03/15 03:05 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
As said above: Always warm the car up in Neutral to get the transmission moving. If I go straight from P to R, I have noticed the same thing the OP describes. I've always assumed its a sign that the converter isn't pumped full.
[Re: Steve88]
#1944259
11/03/15 07:37 AM
11/03/15 07:37 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Sonnax sells a kit to fix this problem along with a bunch of others that were chronic with the 727/904 trannys. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Steve88]
#1944565
11/03/15 09:19 PM
11/03/15 09:19 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
It takes more fluid to go in reverse than drive.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
