5 on 4 1/2 #194357
01/15/09 12:46 PM
01/15/09 12:46 PM
organ
maximum entropy Offline OP
organ
a friend of mine has a 71 scamp with drum brakes in front with 5 on 4 bolt pattern. is there a 5 on 4.5 drum that will fit the a body drum spindle?
Re: 5 on 4 1/2 [Re: maximum entropy] #194358
01/15/09 01:14 PM
01/15/09 01:14 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Not that I know of. You will need to change out the spindles.
Re: 5 on 4 1/2 [Re: maximum entropy] #194359
01/15/09 02:41 PM
01/15/09 02:41 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
On my 69 I used a SSBC convertion kit and they were 5 x 4.5 used the orginal spindales that came on the car.
Re: 5 on 4 1/2 [Re: 69DartGT] #194360
01/15/09 03:13 PM
01/15/09 03:13 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Cheapest way is to get the 73 up A body spindals, brake adapters and calipers at a U pull it yard Oh and upper control arms while at it
Have the rotors turned, rebuild the calipers, slap on new pads,hoses and repack the bearings.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: 5 on 4 1/2 [Re: 69DartGT] #194361
01/15/09 03:48 PM
01/15/09 03:48 PM
this way if your ball joints/bushings are Ok you wouldn't have to open anything up nor have it realigned. EDIT but there have been several issues with ssbc stuff in prior posts. I didn't pay much attention because I never thought I would be purchasing their system.
