Sure Grip weight #194350
01/15/09 12:43 PM
01/15/09 12:43 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Whats the diff between a 8-3/4 sure grip and a steel spool?
Re: Sure Grip weight [Re: Scamp408] #194351
01/15/09 12:52 PM
01/15/09 12:52 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
13 pounds
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Sure Grip weight [Re: Scamp408] #194352
01/15/09 01:01 PM
01/15/09 01:01 PM
It depends on which spool maker and axle size The 35 spline spools weigh less than the 30 splines do but the 35 spline axles are heavier then the 30 spline axles are The lightest combination is the gun drilled and profile milled 35 spline axles and spool, none of the companys that I know of will gun drill the 30 spline axles
Re: Sure Grip weight [Re: Cab_Burge] #194353
01/15/09 04:08 PM
01/15/09 04:08 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
30 spline clutch / spool with lighten holes
Re: Sure Grip weight [Re: Scamp408] #194354
01/15/09 04:24 PM
01/15/09 04:24 PM
BBLM23 Offline
BBLM23  Offline
13 pounds
Walter
1981 Reliant 400
Re: Sure Grip weight [Re: BBLM23] #194355
01/15/09 05:28 PM
01/15/09 05:28 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Any e.t. improvement?
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Sure Grip weight [Re: Jacob Pitt] #194356
01/17/09 05:45 PM
01/17/09 05:45 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I just got done removing my 742 housing with clutch suregrip and scaled at 78.2lbs.My aluminum housing with a steel spool came in at 52.8lbs.I ck them both multi times and came up with an average.Savings of 25.4lbs Iam happy since i had most of the stuff to build the alum center sec.
