Re: Mounting a FireCore Coil
[Re: 70BigBlockSE]
#1942399
10/31/15 06:54 PM
10/31/15 06:54 PM
RapidRobert
I'm going to on my upcoming 451 to keep the coil vertical, propably mod the OE coil bracket/turn it 1/4 turn then work around that. Have SB brackets on hand. here's a BTT for ya.
[Re: Car Nut]
#1942913
11/01/15 12:33 PM
11/01/15 12:33 PM
Posts: 16,162 Mesa, Arizona
dart4forte
Mesa, Arizona
I mounted mine with the factory six pack coil mount
Abe Lincoln
[Re: dart4forte]
#1942940
11/01/15 01:23 PM
11/01/15 01:23 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
With a big block you could mount it to the pass fender and keep it cool away from engine heat. I would not try to make it look stock.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 70BigBlockSE]
#1942943
11/01/15 01:27 PM
11/01/15 01:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The OP never said anything about making it LOOK stock, just that he wanted to MOUNT IT CLOSE TO THE STOCK LOCATION.
[Re: 70BigBlockSE]
#1943296
11/01/15 10:53 PM
11/01/15 10:53 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Wouldn't mounting a coil of that style, on the engine like that, kill it with heat?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
