Re: EZ EFI or Carb?
[Re: UCUDANT]
#1940800
10/29/15 01:40 AM
10/29/15 01:40 AM
Posts: 1,822 Colorado
denfireguy
Colorado
For the same price you can do a Spectra Tank with a Warbro pump that would look stock. Have you replaced your tank? I am in the process of replacing mine but used a Tank, Inc with a Warbro in tank pump. http://www.amazon.com/Spectra-Premium-CR...keywords=cr8cfi The seller at $407 is out of stock however. http://www.tanksinc.com/index.cfm/page/p...prod/prd477.htm Not a package deal but a la cart so you can size the Warbro for what you need Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: EZ EFI or Carb?
[Re: denfireguy]
#1940878
10/29/15 08:50 AM
10/29/15 08:50 AM
Posts: 8,147 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Thanks, I just spotted an ad for tanks inc in Mopar mag. I think I'll look into them today.
Re: EZ EFI or Carb?
[Re: UCUDANT]
#1941111
10/29/15 05:07 PM
10/29/15 05:07 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
I installed the Phantom 340 kit in my Super Bee's tank this past spring. The kit is high-quality and well thought out, but if you do it like they say (just drill a big hole in the tank), the kit will obviously just hit the trunk floor at the highest spot. I ended up spacing my tank down from the trunk using some thick rubber mat, but I'm not completely happy with it like that. The ideal way to do it would be to cut and weld a section of the tank to be lower and then install the kit into that section, but that was more effort than I wanted to do. If I had to do it again (and if it had been available at the time), the Tanks-inc factory style tank is absolutely the way I would do it.
Paul '69 Super Bee 383 EFI Turbo
Re: EZ EFI or Carb?
[Re: Pacnorthcuda]
#1943158
11/01/15 06:59 PM
11/01/15 06:59 PM
Posts: 624 Zombieland
Car Nut
Zombieland
This would look/sound awesome on a 340. I don't understand. In what way would that set up SOUND different than a carb? Bragging rights! If I say I had a six pack efi on my car, doesn't that SOUND better than I have 2 barrel CARB?
Re: EZ EFI or Carb?
[Re: UCUDANT]
#1951074
11/14/15 02:41 PM
11/14/15 02:41 PM
Thumperdart
State of confusion
I`d get a bigger carb and get it properly tuned/modified.......WAY cheaper and more dependable when set up correctly.......
Re: EZ EFI or Carb?
[Re: UCUDANT]
#1951254
11/14/15 10:05 PM
11/14/15 10:05 PM
denfireguy
Colorado
UPDATE: while adjusting to ensure anequate idle vacuum I saw a difference in my Autometer, and shop gauge, I'll figure that out later....
A car I was eyeballing a state away is now suddenly within reach so this is upgrade is on hold. If I get that car, I'll sell a spare "driver" I have stashed and the parts for it, restocking some car cash. Purchase is a week out Glad to hear that, sad to hear that. I was hoping to learn from your experience. Have my injection tank wired but not plumbed. Gauge works...at least on empty. Still getting the return from the pressure regulator routed and connected. Old tank is is gone and disposed of. Could not get the sender out of it due to corrosion. Going to work some more on it tomorrow, looks like that last decent day for a while. Snow coming on Monday. Craig
