750 edelbrock on a 383 #1942936
11/01/15 01:18 PM
11/01/15 01:18 PM
Fargo ND
moparphilll Offline OP
Fargo ND
Is there a throttle lever adaptor so you can still hook up original cable and kick down without a lot of changes???
Thanks in advance
Re: 750 edelbrock on a 383 [Re: moparphilll] #1942944
11/01/15 01:28 PM
11/01/15 01:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes
Don't be the exception.
Re: 750 edelbrock on a 383 [Re: Supercuda] #1942980
11/01/15 02:14 PM
11/01/15 02:14 PM
Edelbrock #1483 throttle adapter, O'reillys etc can order it. & you need that horizontle pin/nut which is a common Mopar OE item or fab your own
Re: 750 edelbrock on a 383 [Re: RapidRobert] #1943174
11/01/15 07:58 PM
11/01/15 07:58 PM
Fargo ND
Fargo ND
they had a 1481 on hand will try it thanks
Re: 750 edelbrock on a 383 [Re: moparphilll] #1943196
11/01/15 08:41 PM
11/01/15 08:41 PM
My bad, I rechecked & the 1481 IS correct. 1483 is for a furd
