Holley Power Valve Question #1941102
10/29/15 03:57 PM
10/29/15 03:57 PM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
What is the life expectancy of a Power Valve with today's pump gas? I have a friend who is getting about 2 years out of a valve before the ethanol eats the rubber. Is this normal?
Thanks!
Re: Holley Power Valve Question [Re: Pynzo] #1941136
10/29/15 04:47 PM
10/29/15 04:47 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I run a Demon 850 in the Charger. Here is CA we have Ethanol in the fuel. They list "Up to 10% Ethanol" but independent tests have shown the gas averages 6%.
I have never had a PV go bad in the carburetor of the Charger or the other 4 Holley carbureted cars I own. I've had the acc pumps fail, probably from sitting too long between startups and the pedal pumping to spring them back to life!
Re: Holley Power Valve Question [Re: Pynzo] #1941151
10/29/15 05:15 PM
10/29/15 05:15 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Same here, never had a PV go bad from the ethanol gas. I have two holleys on my car. That doesn`t mean that they don`t but I never had one fail from gas.
Time just gets away from us
I`m here until I`m not
Re: Holley Power Valve Question [Re: mopars4ever] #1941235
10/29/15 07:18 PM
10/29/15 07:18 PM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
Ok good to know. I just installed my first Holley last spring and figured I'd pick up some spare parts.
Another question- anybody know where to get the Power Valve Socket?
Edit- I found this one at Jegs.
http://www.jegs.com/i/JEGS-Performance-Products/555/150222/10002/-1
Re: Holley Power Valve Question [Re: Pynzo] #1941273
10/29/15 08:09 PM
10/29/15 08:09 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I might be a redneck but I just use a one inch wrench.
Re: Holley Power Valve Question [Re: Pynzo] #1941289
10/29/15 08:36 PM
10/29/15 08:36 PM
md
mopars4ever Offline
mopars4ever  Offline
md
same here
Re: Holley Power Valve Question [Re: forphorty] #1941291
10/29/15 08:39 PM
10/29/15 08:39 PM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
I'm a tool collector. I like doing things the right way. And a foot long wrench, which I have 3 of, is a little extreme for 120 inch pounds of torque. If I can find the factory tool I'll buy it. I have a beautiful Inch pound torque wrench and would love to use it for one more thing. And I'm a certified RedNeck also. With serious OCD!
Thanks anyway
Re: Holley Power Valve Question [Re: Pynzo] #1941450
10/30/15 12:14 AM
10/30/15 12:14 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I would think that there are very few that torque a power valve or there would even be the need to ! And as for the special tool,doesn't look like a torque wrench to me. shruggy
Re: Holley Power Valve Question [Re: 62maxwgn] #1941532
10/30/15 07:15 AM
10/30/15 07:15 AM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
Yep. Appears to be a socket and very small breaker bar. I want the socket but will probably end up buying the Jegs tool.
Re: Holley Power Valve Question [Re: Pynzo] #1941643
10/30/15 12:55 PM
10/30/15 12:55 PM
OT, most people tighten jets too much and the PV not enough
Re: Holley Power Valve Question [Re: RapidRobert] #1941768
10/30/15 06:26 PM
10/30/15 06:26 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I have used a 1" deep well socket with no bar and tighten them by hand. If you have any grip at all you should be able to get it tight enough. In essence that's all the Jegs tool does. twocents
...FAFO...
Re: Holley Power Valve Question [Re: skicker] #1941851
10/30/15 09:52 PM
10/30/15 09:52 PM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
I found numbers for the Kent Moore and Snap On sockets. I'll look for one of them. Thanks
