Re: 2000 Jeep Grand Cherokee Brakes. ATE/Akebono??
[Re: wkroncke17]
#1940957
10/29/15 12:18 PM
10/29/15 12:18 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
I had a 2004 that I drove hard , it seemed like I was chasing pulsating fronts every 5000 miles, I put 80k on it and it drove me nuts .
Good luck.
[Re: wkroncke17]
#1941251
10/29/15 08:35 PM
10/29/15 08:35 PM
Posts: 5,924 ohio
ruderunner
ohio
Clean mounting surfaces for the rotors, good quality rotors ( I like Centric brands premium line) and the correct brake lube ( not antiseize) in the right places. A torque wrench for the lug nuts. After roughly 1000 brake jobs I've very seldom had any pulsation complaints regardless of vehicle. Good practices apply to all brakes.
Angry white pureblood male
[Re: ruderunner]
#1943902
11/02/15 08:20 PM
11/02/15 08:20 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Clean mounting surfaces for the rotors, good quality rotors ( I like Centric brands premium line) and the correct brake lube ( not antiseize) in the right places. A torque wrench for the lug nuts. After roughly 1000 brake jobs I've very seldom had any pulsation complaints regardless of vehicle. Good practices apply to all brakes. Took your advice - did the fronts so far , will do the rears the same! Should be good. Thank you everyone!
