Trans brake valve body questions #1940584
10/28/15 07:31 PM
10/28/15 07:31 PM
jacksonville,FLORIDA
slammedR/T Offline OP
I have a 727 that I will be putting a trans brake valve body in soon. Looking at Coan racing and they have a trans brake reverse pattern and a trans brake reverse pattern but with low band apply. Now I'm thinking of going with the low band apply as I have a steel drum and bolt in sprag so I don't want to have a drum flying into my feet.
Any advice and/or experiences with the two different style trans brakes will be most appreciated.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Trans brake valve body questions [Re: slammedR/T] #1940615
10/28/15 08:19 PM
10/28/15 08:19 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I believe your sprag will be happier with the low band.
Re: Trans brake valve body questions [Re: slammedR/T] #1940696
10/28/15 10:22 PM
10/28/15 10:22 PM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
We just put a new A&A Trans brake with low band apply in our car. I couldn't be happier. I have used several other brand brakes and the A&A is by far the best I have used.
Re: Trans brake valve body questions [Re: Joes66dart] #1940734
10/28/15 11:21 PM
10/28/15 11:21 PM
Don't all the manual low band apply valve body slow the drag cars down some shruggy work
Re: Trans brake valve body questions [Re: slammedR/T] #1940742
10/28/15 11:30 PM
10/28/15 11:30 PM
Didn't think about A&A, I have been happy with their parts and customer service.
racemagnum
Re: Trans brake valve body questions [Re: slammedR/T] #1940743
10/28/15 11:31 PM
10/28/15 11:31 PM
LOL, I think so too but want some opinions
racemagnum
Re: Trans brake valve body questions [Re: slammedR/T] #1940850
10/29/15 05:01 AM
10/29/15 05:01 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I had a nlba TranzAct in the Mirada. It worked great and I ran an aftermarket front drum with stock sprag.
Our 904 has a Griner nlba brake, but it's mostly stock internals and was only behind our high 10 360.
Duster's currently equipped with a 727. It had a Griner LBA, but I sold it and went with a Pro Trans clean N nlba.
....I also have an older Griner NLBA trans brake laying around doing nothing that worked from the trans it came out of.
A friend has an older Coan Trans brake, and it looks like a Griner.
Re: Trans brake valve body questions [Re: J_BODY] #1940865
10/29/15 07:25 AM
10/29/15 07:25 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
I'm 99.9% sure that the 727/904 transbrakes sold by Coan are actually TranZact.
Re: Trans brake valve body questions [Re: Cab_Burge] #1940871
10/29/15 08:23 AM
10/29/15 08:23 AM
Q
Quicktree Offline
Quicktree  Offline
Q
heard as much as .1 or more. and keep in mind you have to mash a button to get reverse.
