Leveling a 2nd gen 2wd ?
#1940540
10/28/15 06:20 PM
10/28/15 06:20 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
I need to add front spring spacer to my 01 2500 because my tires rub on a hard turn, are all the available spacers basically the same?
Re: Leveling a 2nd gen 2wd ?
[Re: JohnRR]
#1940958
10/29/15 12:18 PM
10/29/15 12:18 PM
JohnRR
U.S.S.A.
So no one has a 2wd 3/4 ton they leveled ?
[Re: JohnRR]
#1942049
10/31/15 11:17 AM
10/31/15 11:17 AM
JohnRR
U.S.S.A.
It appears there is a GM application spring that fits the Ram that will raise the front about an inch and a half, better than plastic spacers I think.
[Re: BulletBob]
#1942050
10/31/15 11:18 AM
10/31/15 11:18 AM
JohnRR
U.S.S.A.
I moved the spring hangers up on the frame on my CrewCab & a bunch of others I need tire clearance in the front so lowering the back wouldn't really help me there , but thanks
