Re: frame connecters
[Re: mikepar]
#193959
01/15/09 02:13 PM
01/15/09 02:13 PM
Posts: 6,516 Santa Cruz, California
Lefty
Seems like these could be had alot cheaper than some connecters sold by some frame repair companys
The extra cost is because they have already cut them to fit your chassis. Some are cut to fit the contour of the floor pan. That way they don't stick up above the factory floor pan and cause the carpet to not fit. You can do it yourself and save some money but you will see them sticking up through the floor pan inside the car and you will have to cut the floor pan to fit them. You can go with 2x2" and not have to cut the floor pan, but they will not be as strong as the 2x3s.
[Re: DaytonaTurbo]
#193961
01/15/09 06:14 PM
01/15/09 06:14 PM
Posts: 327 pittsburgh,Pa.
mikepar
pittsburgh,Pa.
the hinges are good Im assuming there may be some bending/flexing
thanks for the reply
[Re: mikepar]
#193963
01/15/09 08:36 PM
01/15/09 08:36 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
The frame connectors in my '65 Dart are simply 2X3X1/8" mild steel. Super easy to build and install. The floor does need to be slotted though, so you will need to redo your carpetting.
This is the land of the free
because of the brave
[Re: rbstroker]
#193964
01/16/09 12:41 AM
01/16/09 12:41 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
correct me if I'm wrong, but aren't there plenty of subframe connectors on the market that DON'T have to be recessed into the floor?
[Re: StealthWedge67]
#193965
01/16/09 01:14 AM
01/16/09 01:14 AM
DaytonaTurbo
Manitoba, Canada
Yes but they cost more and are not as strong as the ones that keep their square shape and go through your floor.
[Re: Magnum]
#193967
01/16/09 01:17 PM
01/16/09 01:17 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
I agree with this 100% and that is the way my last 2 connectors were in a Dart and a Super Bee.
Next question is. Without a cage, does it need to be that strong? How much thicker does it need to be compared to the factory frame?
All I see it doing is transfering load of the rear frame into the front frame. Since the entire deal is flat (no cage), not seeing too much torsional strength anyways. Like a pick up truck.
So are you guys saying that the MP subframe connectors and the ones they sell through Mancini are no good and dont add any benefit to the chassis itself?? These have been used by many racers for a long time and they seemed to have worked everytime. I am not saying that installing them through the floor pan is not better but I feel that these do work and will stiffen up your Mopar.
[Re: Blakcharger440]
#193968
01/16/09 01:47 PM
01/16/09 01:47 PM
rbstroker
West Tennessee
The original question was about frame connectors for an early (1966) "A" body. I am not sure that they are commercially available. If they are, naturally they would help strengthen the chassis (almost anything would). I believe that unless there is an overwhelming need to have the floor under the seats appear stock, it is much cheaper and much stronger (especially with the '66 convertible) to slot the floor and weld everything completely solid. Just my 2 cents.
[Re: rbstroker]
#193969
01/16/09 04:33 PM
01/16/09 04:33 PM
Posts: 350 central IL
myduster360
central IL
^^^I agree for the most part but why be statisfied with just a "little stiffer". Either try to make the chassis as stiff as you possibly can or not. Why half-a$$ it ??
Since our car are unibody, the Inner and Outer rocker panels along with the floor pan, are the "Frame" right? With that said, to get the "most" chassis stiffening when installing frame connectors you should:
1) Weld as much of them to the floor pan as possible. The contoured ones XV and a few vendors sell are nice and are the next best thing to huge square tubing.
2) Box the front the rear of the Rocker panels, A-la' convertibles and hemi cars. Don't be fooled thinking thin sheets of metal are a waste. They work.
Other aftermarket tube connectors, if availible, aren't near as good plus they cost more.
1972 Swinger 3.6L Pentastar Diablo CMR tuner
[Re: myduster360]
#193970
01/16/09 11:41 PM
01/16/09 11:41 PM
Posts: 412 Cleveland,Ohio
CtownChris
Cleveland,Ohio
Check out www.chassisengineering.comMopar $99.50 plus shipping. They are very large not thin walled. Have them on 71 RR. These do not go through the floor but are a liitle low. Never hit a driveway though.
"Always go forward: Never go straight"
[Re: myduster360]
#193975
01/17/09 04:52 PM
01/17/09 04:52 PM
rbstroker
West Tennessee
I have the 2X2X1/8 square tubing connectors in my Coronet because I didn't want to cut the floor. It is unbelievable how much more rigid the Dart with 2X3X1/8 connectors through the floor is. When the Coronet is on a lift, the doors hang up a bit. The Dart doors close and open easily.
[Re: myduster360]
#193977
01/17/09 07:35 PM
01/17/09 07:35 PM
Lefty
They are called "shear plates" and really work well.
