What solution 4 cleaning painted/running engine? #1939093
10/26/15 07:03 PM
10/26/15 07:03 PM
fullmetaljacket Offline OP
I want to spruce up and clean the mild surface grease sweat on my engine that is still in my car for some pictures.
What do you guys use that will not blemish or remove the engine paint, but will remove the grease/dust?
Thank you.
Re: What solution 4 cleaning painted/running engine? [Re: fullmetaljacket] #1939099
10/26/15 07:16 PM
10/26/15 07:16 PM
Middle of Illinois
Ski 61701 Offline
Ski 61701  Offline
Middle of Illinois
Maybe Dawn dish soap mixed with some water in a spray bottle? I would try it on a cool engine just to be safe. Rinse really well. If it removes the oil from animals that were caught in an oil spill and it doesn't hurt them, I can't see why it wouldn't work on a slightly dirty motor.
Re: What solution 4 cleaning painted/running engine? [Re: Ski 61701] #1939108
10/26/15 07:27 PM
10/26/15 07:27 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Lee diluted Simple Green works well and then hose off.
Ron
Re: What solution 4 cleaning painted/running engine? [Re: RJS] #1939137
10/26/15 07:57 PM
10/26/15 07:57 PM
Thanks guys.
Re: What solution 4 cleaning painted/running engine? [Re: fullmetaljacket] #1939153
10/26/15 08:27 PM
10/26/15 08:27 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I use something called Formula 88, only $7 a gallon to, the onl y problem you'll have is it does seem to be available anywhere but Florida which really doesn't make sense since it is eco friendly. Works awesome, I have provided it to some friends and they cant believe the stuff. After it I will go over the engine and undercarriage with dish soap water like you wash the outside of the car and yes with the engine cold.
Careful, your character's showing!
Re: What solution 4 cleaning painted/running engine? [Re: fullmetaljacket] #1939285
10/26/15 10:45 PM
10/26/15 10:45 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
After rinsing chosen detergent off, rinse again with deionized water if you have such an instrument to produce it. Several excellent such products exist.
Else rinse with a gallon of distilled water that can be purchased at any grocery store.
Saves a lot of drying time by towels and eliminates spotting.
Best to start engine asap to help dry out alternator, dizzy, wiring etc.
Re: What solution 4 cleaning painted/running engine? [Re: fullmetaljacket] #1939367
10/27/15 12:12 AM
10/27/15 12:12 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Citrus based degreaser, like from ZEP, works great. The citrus oil is like a solvent and will penetrate the slime buildup better than some others. Your foamy type cleaners, like GUNK, just sit on the surface and don't dissolve the goo. They will, however, trash painted surfaces by killing the paint. This applies to the purple cleaners too so be careful what you use. I like the ZEP orange cleaner. I have it in a 1 gallon pump up garden sprayer which works awesome for getting it where you can't by other methods because the spray wand gets wherever it can be poked into.
Carl Kessel
Re: What solution 4 cleaning painted/running engine? [Re: RJS] #1939384
10/27/15 12:31 AM
10/27/15 12:31 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Ron
iagree
standard issue, (not diluted) Simple green on a cold motor engine compartment works wonders. if a compressor or leaf blower is available, blow out the pockets and towel dry
twocents
