Re: Another year,same results
[Re: Clanton]
#1938982
10/26/15 03:42 PM
10/26/15 03:42 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
intake reversion. rust shadow bearings after 20 runs
[Re: Clanton]
#1939082
10/26/15 06:41 PM
10/26/15 06:41 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
I see several things that do not look good, out of round bore, blower manifold gasket not sealed up well and possibly detonation on the rod bearing. I don't like the cylinder wall finish either, was that done with a ball, dingleberry hone? If so time for a torque plate hone to get the cylinders round again If not done with a dingleberry, ball hone maybe it is time for a different machine shop choice How much duration overlap, lobe seperation angle and what intake lobe center was that cam installed at?
[Re: Clanton]
#1939122
10/26/15 07:45 PM
10/26/15 07:45 PM
Clanton
northern,Ohio,USA
Any reversion,oil in intake,bad tune/detonation,ring flutter,crank case psi was caused by an oil leak in the intake port from porting.I am sure power went past the rings in the cylinder with the shadow.
