I'm in the process of putting my 64 Polara back together and of course I cannot remember how to properly mount the hood hinges. I have the speed nut on inner fender for the front mounting point. The lower rear mount has the nut welded to the inner fender. Problem is the top rear mounting hole. On the inner fender there is rectangle hole right where the hinge mounts, and of course I don't what type of nut goes there. If anyone has a picture of this spot with the proper mounting nut it would be greatly appreciated.
