any dodge techs out there 01 stratus fuel problem #193811
01/14/09 10:05 PM
01/14/09 10:05 PM
central pa
darted1 Offline OP
darted1  Offline OP
central pa
01 stratus se with 2.7 magnum how to tell if it is the pump or something else that controls the pump? when you turn the key you do not hear the pump run. i have the pump out of the tank.thanks ed
ED M
Re: any dodge techs out there 01 stratus fuel problem [Re: darted1] #193812
01/15/09 10:48 AM
01/15/09 10:48 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Easiest way is to inject some brake cleaner in the throttle body and see if the car starts and runs briefly. 98% of the time it is the pump and not a controlling problem. With the pump out of the car hook + and - and see if it runs this may not help if the pump runs but does not supply the necessary volume/pressure
Re: any dodge techs out there 01 stratus fuel problem [Re: darted1] #193813
01/15/09 11:36 AM
01/15/09 11:36 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
ck voltages at the connector, if all is good , chances are really good it's the pump ( common on JA cars )
