scaling a car/ advise #193805
01/14/09 09:56 PM
01/14/09 09:56 PM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
i am thinking about getting the car scaled, just what should i do with info that i get, the front end is stock with comp 90/10 shocks/ 6 cyl torsion bars .......the rear is a cal track mono leaf with rancho 9 ways... im just not sure where to go once i get the #'s, its not like its a tube cassis 4 link deal that you can change weights by turning this and that,,,any input welcome, thanks mike
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: scaling a car/ advise [Re: Stroker Scamp] #193806
01/14/09 10:08 PM
01/14/09 10:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yes you can change the #`s quite a bit by pre-loading or un-loading the caltracs. If you locate my old "scaled my dart today" post you can read all about it. Also by raising/lowering the ft. end w/the t-bars, you can put a good amount weight on the rear and I got my l-r rear #`s within 2lbs of each other and got my new best.
Re: scaling a car/ advise [Re: Stroker Scamp] #193807
01/14/09 10:49 PM
01/14/09 10:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When your on the scales have your caltracs set at 0
load then adjust the T bars so the rears are equal
weight then dial in your caltracs for preload, as
thunder said maybe 20 lbs or less then check it on the track
EDIT
Remember this is with you or your weight in the seat
Re: scaling a car/ advise [Re: MR_P_BODY] #193808
01/15/09 12:52 AM
01/15/09 12:52 AM
pacific northwest
pacific northwest
thanks guys, ive got a chassis book (dave morgan) but reading that thing weirds my brain out,,, ive got a little better idea of what to do, thanks
Re: scaling a car/ advise [Re: Thumperdart] #193809
01/15/09 01:05 AM
01/15/09 01:05 AM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
Here it is. https://board.moparts.org/ubbthreads/show...rue#Post4848155
Re: scaling a car/ advise [Re: StrokerPost] #193810
01/15/09 11:27 PM
01/15/09 11:27 PM
Saskatchewan, Canada
barracudabob Offline
When i scale mine, I put bags of softener salt on the seat and floor. I weight 160 with my helmet and jacket on, so I use three bags of salt, and a bag of kitty litter. It works for me!
