2002 Ram brakes sometimes don't seem to grab
#1937796
10/24/15 04:05 PM
10/24/15 04:05 PM
Posts: 836 Up a holler, down a crick
booger
I've got a recurring problem with my 2002 Ram 2500 CTD, where sometimes the brakes just don't seem to grab, to where I have to really put my foot down to stop it. So far it's only happened at slow speeds, and it happens out of the blue. For example today I probably drove about 50 miles total, no problem, back home, then at the end of my driveway rolling < 5 MPH or so, it happened.
In a way it feels like the ABS has kicked in and it's grabbing and releasing, but the ABS light isn't on so I guess that means there's no codes. I don't hear the pucka-pucka-pucka sound that usually happens when the ABS is active either.
Another way to describe it would be that it feels like the rotors are glazed up, to where the brakes activate but don't stop, but it doesn't happen every time so I'm unsure if that could be it. 99 times out of 100, the brakes work fine. Also, the pads are good on all four wheels.
Has anyone else experienced this? Any tips/comments on what could be going on are appreciated.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: 2002 Ram brakes sometimes don't seem to grab
[Re: booger]
#1937931
10/24/15 08:28 PM
10/24/15 08:28 PM
booger
What does a CTD use for power brakes? Good question - I googled it and apparently the power steering pump provides fluid to a hydroboost gadget. Hydroboost comes after the steering gear box, so if it was the PS pump going bad, I'd notice it in the steering first. That could be it since it's only happened at low speeds. If it's running down the road it's built pressure so things work. No oil under the truck indicating a leak. Will look at it tomorrow and read up on it tonight. Thanks
[Re: booger]
#1938171
10/25/15 08:12 AM
10/25/15 08:12 AM
Posts: 5,807 ohio
ruderunner
ohio
Sounds like a failing master cylinder. Try this: ease into the pedal slowly and smoothly, does it seem to have excess travel? Then compare to a quick hard hit, does the pedal travel as far before getting firm? If step one is yes and step two is no then the master is most likely bypassing.
They use lip seals and the slow push doesn't force the seal to expand, the fast push does hence the better pedal on a quick hit.
Angry white pureblood male
[Re: booger]
#1938186
10/25/15 09:45 AM
10/25/15 09:45 AM
booger
The pedal feels and travels like it always has, the truck just won't stop. If I push harder, it does.
[Re: booger]
#1938234
10/25/15 11:57 AM
10/25/15 11:57 AM
Posts: 13,583 md
mopars4ever
md
[Re: booger]
#1938945
10/26/15 02:54 PM
10/26/15 02:54 PM
booger
I just checked the PS fluid (like to never found it), motor off and cold the fluid isn't on the stick at all, I can see the fluid down in the pump so it's not dry but nowhere near the level it should be.
[Re: booger]
#1939310
10/26/15 11:04 PM
10/26/15 11:04 PM
Posts: 5,807 ohio
ruderunner
ohio
PS coolers like to rot on this generation of truck.
[Re: booger]
#1939500
10/27/15 10:05 AM
10/27/15 10:05 AM
booger
Thanks for all the tips.
I looked around for leaks and noticed a lot of grime under the truck in the area around the PS pump, but the concrete under it is dry and clean and always has been. OTOH, a tiny leak could add up over a 13 year time span. I'll definitely look at the cooler and also check it out with the motor running.
I'll fill the fluid, and if it turns out to be something more I'll update this thread with questions.
Thanks again
[Re: booger]
#1939582
10/27/15 12:02 PM
10/27/15 12:02 PM
booger
Good idea I'll get a longer dipstick to stick in there and check that out before I add any new fluid. Should be OK though, truck is hardly used at all and definitely isn't used hard.
[Re: booger]
#1943635
11/02/15 01:54 PM
11/02/15 01:54 PM
booger
FWIW, I filled the PS but the brakes still act up
