Electric fuel Pump wiring through pressure switch question..
#1936892
10/22/15 07:19 PM
10/22/15 07:19 PM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
Hey Guys quick question, I'm wiring an electric fuel pump through an oil pressure switch as a safety cutoff for a customers car... engine is a 440, can I install the switch into the extra port in the rear of the block beside the regular oil pressure switch location or should I use an adapter and run it off the same port ? Is there a better location I'm missing ?
Or.... I don't suppose there's one sending unit/switch "all in one" out there that will read resistance for the gauges and act as a switch for the fuel pump ??
thanks...
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
Re: Electric fuel Pump wiring through pressure switch question..
[Re: smac77]
#1937263
10/23/15 01:30 PM
10/23/15 01:30 PM
smac77
Caledon, Ontario
[Re: smac77]
#1937299
10/23/15 02:41 PM
10/23/15 02:41 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
You need to run separate switches for this application. The fuel pump cutoff switch is a normally open (on-off) type pressure switch. In other words, it is an open circuit until the oil pressure reaches a set amount like 15 psi etc.
Be sure you run a relay and use the low oil pressure switch on the "trigger" side of the relay. Do not run the main fuel pump voltage/amperage through the cutoff switch. It will fry it in a short time.
I also ran a bypass toggle switch inside the car, so I can run the fuel pump without the motor running to prime the carbs etc.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
