Bronze or coated dist gear for solid roller? #1936539
10/22/15 02:37 AM
10/22/15 02:37 AM
State, country, etc.
gss Offline OP
gss  Offline OP
I haven't had any issues with the bronze gear in the past but Crane claims their special coated gear is a "lifetime" gear. Any experience, good or bad, that you can share?
Also, any advantage to getting the gear already pinned to the shaft vs. swapping gears?
Thank you
Re: Bronze or coated dist gear for solid roller? [Re: gss] #1936925
10/22/15 07:59 PM
10/22/15 07:59 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
The one in my BB is bronze and also coated. There is a small hole drilled in the oil passage close to the gear that spares oil on the gear. motor has 5000 miles on it and the gear looks like new.
Re: Bronze or coated dist gear for solid roller? [Re: Darryls-Demon] #1937430
10/23/15 06:42 PM
10/23/15 06:42 PM
gss Offline OP
gss  Offline OP
What brand is it?
Re: Bronze or coated dist gear for solid roller? [Re: gss] #1937473
10/23/15 08:17 PM
10/23/15 08:17 PM
I have used pinnned and unpin BB oil pump drives, never a problem with either as long as something solid doesn't get sucked up into the oil pump. I have reused stock oil pump shafts for the bronze aluminum roller cam gears years ago when that was the only option with no pins or problems either later work thumbs If Crane says lifetime warrenty I would probally buy one of those if I needed one twocentsI ran a Mopar brand bronze oil pump drive on my old pump gas Duster for around 3000 street miles and a bunch of 1/8 and some 1/4 mile passes shifting at or above 7000 RPM on it with no measureable wear or problems shruggy
