anyone have 15x10 centerlines on 70 charger? #1936155
10/21/15 02:13 PM
10/21/15 02:13 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
I want to put 15x10 centerlines with a 295/55/15 tire on a 70 charger but the backspacing on the centerlines is only 4 7/8 so not sure if they will fit.Wondering if anyone out in moparts world is actually running this combo on a second gen charger with stock wheel tubs and wheel lips,thanks!
Re: anyone have 15x10 centerlines on 70 charger? [Re: ogopogo] #1936212
10/21/15 04:05 PM
10/21/15 04:05 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I am running 15x10 Magnum 500 with 5" backspace. BFG Radial TA 295/50/15 with no issues or rubs. I'm also using the MP SS Springs. I've got the stock Dana 60 which is off centered a tad bit. You can use a 15 x10 rim with either 5"-5 1/2" backspace on a 70 Charger.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: anyone have 15x10 centerlines on 70 charger? [Re: 70sixpkrt] #1936434
10/21/15 10:56 PM
10/21/15 10:56 PM
missouri
ragin sonny Offline
ragin sonny  Offline
missouri
I've got 15x10 centerline auto drags 295 15 m/t drag radials on my 69 r/t.fit fine. actually fit a lot better than the protract n-50-15s I used to run years ago
Re: anyone have 15x10 centerlines on 70 charger? [Re: ogopogo] #1936485
10/22/15 12:25 AM
10/22/15 12:25 AM
Adelaide Australia
P
peter Offline
peter  Offline
P
Adelaide Australia
I have a 69 charger with 15x10 centerlines with a 295/55/15 tire and a 4 7/8 back space & NO scraping.
Re: anyone have 15x10 centerlines on 70 charger? [Re: peter] #1936524
10/22/15 01:41 AM
10/22/15 01:41 AM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Ok thanks Guys!!
Id love to see a couple pics of those cars with the 10in centerlines....
Re: anyone have 15x10 centerlines on 70 charger? [Re: ogopogo] #1936812
10/22/15 04:49 PM
10/22/15 04:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I ran 15x9's w/ a 275/60/15 and there was enough room for more. Check the backspacing and make sure the sidewalls are clear. Probably a 5" backspace would work.
Coming soon!!!!
Re: anyone have 15x10 centerlines on 70 charger? [Re: Mr.Yuck] #1936814
10/22/15 04:53 PM
10/22/15 04:53 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Here's my old '68 with 15x10 Centerlines and 295/60/15's.
Stan
Re: anyone have 15x10 centerlines on 70 charger? [Re: ogopogo] #1937287
10/23/15 02:25 PM
10/23/15 02:25 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
15x10 Cenerlines....not sure what tire I have on it....hasnt run in years
Re: anyone have 15x10 centerlines on 70 charger? [Re: ogopogo] #1937400
10/23/15 05:41 PM
10/23/15 05:41 PM
AndyF Online content
AndyF  Online Content
I have 15x10 Centerlines on my '65 Dodge with 325/50-15 tires. I can post a picture if you want but it is a different body style than yours. I had to use a wheel with a lot of backspacing to get them on there. I think the backspacing was more than 6 inches.
