How do I take the dash out of my 67 b body?
#1935921
10/21/15 12:33 AM
10/21/15 12:33 AM
Posts: 1,572 wisconSIN
Blown61
wisconSIN
Re: How do I take the dash out of my 67 b body?
[Re: Blown61]
#1935947
10/21/15 01:27 AM
10/21/15 01:27 AM
Posts: 905 SD
zrxkawboy
SD
See the latest issue of Mopar Action - they did an article on this very topic! Lots of helpful details!
It's Swifty! Swifty, you toad sucker!
[Re: Blown61]
#1935955
10/21/15 01:38 AM
10/21/15 01:38 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
The dash frame ? The bolts that hold the frame to the body are under the windshield rubber gasket ...
[Re: NANKET]
#1936107
10/21/15 12:44 PM
10/21/15 12:44 PM
RapidRobert
I ain't a B body guy but I have to drop the st column aways so the dash has room to come forward & up and out & place a rag on the col to protect its paint during the R&R. undo the bolts that hold the column to the underside of the dash (support the column) and first loosen the 3 bolts on the floorboard toe plate so the col has room to move WO binding anything. #1 With electrical the first step is always pull a batt cable off of its post. take off the nuts for the red and black ammeter main wires and CAREFULLY pry the black round connector EVENLY off of the pins on the printed circuit board and there will be some fold over tabs that secure the looms along its route
[Re: terzmo]
#1936247
10/21/15 05:10 PM
10/21/15 05:10 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
disconnect battery...lower steering column,remove radio/knobs/heater control knobs...remove all screws to cluster...reach around and disconnect speedometer cable....slowly pull cluster forward and disconnect connectors/wires to volt meter. yes....I'm referring to a Dodge
[Re: Blown61]
#1936721
10/22/15 02:55 PM
10/22/15 02:55 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
You will have to remove the WS to get to the bolts that hold the metal dash frame to the car..
