1968 Coronet R/T HOW do I verify? #1935827
10/20/15 09:57 PM
10/20/15 09:57 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Looked at this car yesterday (WS23L8 auto). What numbers should be on the eng/trans and where on the body will they be found? Numbers affect value, Widow and Son want me to make an offer. Thanks!
Come on Guys!
Re: 1968 Coronet R/T HOW do I verify? [Re: 68GTS383] #1935881
10/20/15 11:17 PM
10/20/15 11:17 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
In 68 I think only the broadcast sheet ties it all together. The car will be stamped with the sales order number, not the serial number. Only the sheet has both on it.
The motor / trans, if stamped, will be stamped near the oil sender and directly across on the transmission.
Re: 1968 Coronet R/T HOW do I verify? [Re: 68GTS383] #1935893
10/20/15 11:41 PM
10/20/15 11:41 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Re: 1968 Coronet R/T HOW do I verify? [Re: 68KillerBee] #1935977
10/21/15 02:19 AM
10/21/15 02:19 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Does the car have an authentic fender tag?
The fender tag ties the Shipping Order Number (SO#) to the Scheduled Production Date (SPD).
The VIN sequence number will also be specific for a single Scheduled Production Date (SPD).
The Broadcast Sheet will list SPD, SO#, VIN, and much more.
Re: 1968 Coronet R/T HOW do I verify? [Re: 68GTS383] #1936145
10/21/15 01:55 PM
10/21/15 01:55 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
vin numbers on motor...just above oil pan lip on passenger side
Re: 1968 Coronet R/T HOW do I verify? [Re: terzmo] #1936151
10/21/15 02:06 PM
10/21/15 02:06 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Not on 68. VIN is stamped on block on flange where transmission or bell housing bolts to.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 1968 Coronet R/T HOW do I verify? [Re: RoadRunner] #1936310
10/21/15 07:34 PM
10/21/15 07:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Not on 68. VIN is stamped on block on flange where transmission or bell housing bolts to behind the drivers side cylinder head.
wink
Re: 1968 Coronet R/T HOW do I verify? [Re: 68GTS383] #1936790
10/22/15 04:18 PM
10/22/15 04:18 PM
MD
p d'ro Offline
p d'ro  Offline
MD
Is the SO # on the core support like in 67?
Re: 1968 Coronet R/T HOW do I verify? [Re: p d'ro] #1936793
10/22/15 04:23 PM
10/22/15 04:23 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes, but without the Scheduled Production Date.
Re: 1968 Coronet R/T HOW do I verify? [Re: 68GTS383] #1937231
10/23/15 12:20 PM
10/23/15 12:20 PM
MD
p d'ro Offline
p d'ro  Offline
MD
But if it matches the tag SO you can link the body code WS23L at least...
