Re: Need transmission advice... or part.
[Re: None2Slow]
#1935375
10/20/15 02:08 AM
10/20/15 02:08 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
You may be able to fix this with a little machining and a thicker shim (if available). However the rest of the transmission should be made scrupulously clean because there maybe microscopic particles that passed through the filter and into the lockup converter and if you were to reuse it in the build you may be looking at a comeback. Also be sure to flush the trans cooler lines and the cooler itself. I went through a similar problem when my wife owned a Phord Expedition. The first time it failed I pulled the trans pan and found enough aluminum chunks there to make a small block piston. The lockup converter was at fault. I went through 3 transmissions in that POS at $3K a time and the last time they replaced the radiator because the trans cooler was plugged up with debris. The truck is still in the family though now it is not my problem and it has been consigned to death at the hands of my sons employees.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: gtx6970]
#1935567
10/20/15 02:49 PM
10/20/15 02:49 PM
Polarapete
Graham, WA
Another thing you could do is to use a late model truck pan that fits the 904 style trans. I think they are used in the Dakotas and I don't remember the new model number, but the point is that in the 727 style 518 pans the factory puts a small magnet in the corner of the pan and it traps steel filings. A worthwhile addition to your fresh trans.
[Re: None2Slow]
#1935587
10/20/15 03:11 PM
10/20/15 03:11 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
That damage is typical when the fiber thrust washer pounds out or is omitted, you can see where the pilot is peened over from bottoming out in the input shaft.
I agree that it can be saved with some lathe work, face off the thrust surface and remove the peening being careful not to undersize the pilot. The thickest selective washer might make up for the removed material.
[Re: None2Slow]
#1936654
10/22/15 12:28 PM
10/22/15 12:28 PM
Posts: 12,141 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Is that where the output and input shafts meet? If so, A&A has a bearing for that location for the 727, but I don't know about the smaller tranny. You might check with them and see. The bearing is not listed in their catalog, but is available. I have put a couple in my 727s over the years after beating out the thrust washers.
Master, again and still
