Brazing cast iron #1935129
10/19/15 08:21 PM
10/19/15 08:21 PM
Maryland
twayne24365 Offline OP
Maryland
I have a set of fully ported 452 heads and they were epoxied on the side of the ports. One of the pieces of epoxy was loose so I carefully ground it off. Would it be better to braze these shut or re epoxy them?
Re: Brazing cast iron [Re: twayne24365] #1935132
10/19/15 08:26 PM
10/19/15 08:26 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
ONLY if you know how to braze cast iron, you could make scrap out of them fast.
Have a great day
Iowan
"obsolete is neat"
Re: Brazing cast iron [Re: twayne24365] #1935161
10/19/15 08:58 PM
10/19/15 08:58 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
There is a tig rod out, that doesn't require a preheat and is supposed to work really well. I'll see if I can find the name of the filler material.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Brazing cast iron [Re: DemonDust] #1935172
10/19/15 09:12 PM
10/19/15 09:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Silicon/bronze. I would still suggest preheat but it works very well.
Doug
Re: Brazing cast iron [Re: twayne24365] #1935189
10/19/15 09:33 PM
10/19/15 09:33 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
You can use silicon bronze, but I'd use EZ Weld tig filler rod.
You can buy it here
EZ Weld tig wire
SDG Motorsports
Re: Brazing cast iron [Re: twayne24365] #1935202
10/19/15 09:50 PM
10/19/15 09:50 PM
Maryland
Maryland
That ez tig filler seems interesting, I'd assume it's better than just the flux coated brass rods?
Re: Brazing cast iron [Re: twayne24365] #1935203
10/19/15 09:55 PM
10/19/15 09:55 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Well the flux coated brass rods are only for oxy/acety welding.
I'd much rather use a gas lens, with a 12 pyrex cup. That way you can get the tungsten in the port, be able to see, and have plenty gas coverage.
SDG Motorsports
Re: Brazing cast iron [Re: twayne24365] #1935209
10/19/15 09:57 PM
10/19/15 09:57 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Great setup for tight places.
SDG Motorsports
Re: Brazing cast iron [Re: twayne24365] #1935210
10/19/15 09:57 PM
10/19/15 09:57 PM
Maryland
Maryland
So that rod has to be used in conjunction with a tig welder? Good thing I know someone that has one
Re: Brazing cast iron [Re: twayne24365] #1935214
10/19/15 10:01 PM
10/19/15 10:01 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Yes it's for tig welding. Without shielding gas it's not going to work properly.
SDG Motorsports
Re: Brazing cast iron [Re: twayne24365] #1935219
10/19/15 10:04 PM
10/19/15 10:04 PM
Maryland
Maryland
Ok, well thanks! That gives me some hope, I hate to see these ol heads go to waste, someone definitely put some money into the porting, pushrod area has been tubed as well, I just don't trust the epoxy, especially if I go e85
Re: Brazing cast iron [Re: twayne24365] #1935222
10/19/15 10:05 PM
10/19/15 10:05 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Regular er70s you could use with a torch, but with a custom blend, I'd ask the manufacturer.
SDG Motorsports
Re: Brazing cast iron [Re: twayne24365] #1935225
10/19/15 10:11 PM
10/19/15 10:11 PM
Maryland
Maryland
Well for 27 bucks that ez wire may just be worth a try
Re: Brazing cast iron [Re: twayne24365] #1935242
10/19/15 10:28 PM
10/19/15 10:28 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
I vote for the epoxy. Splash zone seems to work for most... I would not weld them. Too many successful applications of epoxy in heads to chance welding it up...
Re: Brazing cast iron [Re: twayne24365] #1935243
10/19/15 10:30 PM
10/19/15 10:30 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I Had a crack in the bowl in one of my well ported 452 heads. I took it to an a very good old guy at the welding shop to try and braze it. He could not get it to seal up. On a side note, If you can't get it fixed I have a ported 452 I would sell cheap. grin
The only Carbs I care about are under the hood!
Re: Brazing cast iron [Re: twayne24365] #1935298
10/19/15 11:43 PM
10/19/15 11:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If all you want to do is fill a void then epoxy is a safe method. If you need to repair a crack then it has to be welded. Brazing doesn't cut it. In "the old days" you would arc weld it with ni-rod. I know nothing about tigging cast iron but if I were doing it I'd want to pre-heat the whole head. Bob Glidden used to use a pizza oven. I think a good size gas bar-b-que would work just fine.
