Re: Quietest electric fuel pump [Re: John_Kunkel] #1935033
10/19/15 05:21 PM
10/19/15 05:21 PM
On the return Q would a fitting in the (return) line with a carb jet (or similar, NPT pipe plug) drilled to a particular size give the proper amt of return flow?
Re: Quietest electric fuel pump [Re: John_Kunkel] #1935048
10/19/15 05:34 PM
10/19/15 05:34 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Originally Posted By Stanton
The FITech recommendation is a 3 - 8 psi pump feeding the surge tank and this will supposedly support 1200 HP (not that I'm anywhere close to that!) Presumably they've done some testing !!!
It's not about how many horses it'll feed, it's about how long it'll feed 'em. IOW, it won't feed 1200 horses for an extended period of time but the capacity of the tank plus the inflow will probably be sufficient for the typical length of time you're producing 1200 HP (quarter mile run, dyno pull)
Yeah, I understand that.
Re: Quietest electric fuel pump [Re: Stanton] #1935054
10/19/15 05:45 PM
10/19/15 05:45 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
The problem with that is its "hit and miss". You could run a 3/8 feed line and a 1/8 return but is that enough or too much ?!?!? This is why I think they recommend a low pressure pump - adequate to keep the surge tank full "most of the time" but not enough pressure to require a return line.
The alternative (in my opinion) would be more volume and a return line with a regulator set a hair below the surge tank's threshold.
Re: Quietest electric fuel pump [Re: Stanton] #1935582
10/20/15 03:04 PM
10/20/15 03:04 PM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
then you are probally better off with an Aeromotive A1000 & a return regulator/ line than using the sump kit. Same size line going both ways. Size depends on the engine requirements, but -8 will feed 98%. drive
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: Quietest electric fuel pump [Re: Stanton] #1935602
10/20/15 03:38 PM
10/20/15 03:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is no provision on the FITech surge tank for a return line.
Even though their website pics don't show it, the current version of the tank does have a return port.
Re: Quietest electric fuel pump [Re: John_Kunkel] #1935633
10/20/15 04:22 PM
10/20/15 04:22 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
If the return is still there, run the same size return line back to the fuel tank and disable the float inside the tank. The internal high pressure pump does not require pressurized fuel to work in the can. It needs only a continuous supply of fuel.
This low pressure side of the fuel system delivers fuel until the tank is full and free flows back to your main tank. Any restrictions will increase the low-side pressure dramatically.
