Vent Window Delete? #1931708
10/13/15 10:44 PM
10/13/15 10:44 PM
New Brunswick, Canada
TrxR Offline OP
TrxR  Offline OP
Has anyone here ever seen or done a Vent window delete on a 70's - 90's Dodge ram?
Re: Vent Window Delete? [Re: TrxR] #1931946
10/14/15 12:15 PM
10/14/15 12:15 PM
scratchnfotraction Offline
I have on a mid 80s race truck with no roll down windows.
plexy glass cut and screwed off on door frame.
the vent window is built into the glass slide channel so nothing holding the glass if removed.
Re: Vent Window Delete? [Re: scratchnfotraction] #1931997
10/14/15 01:54 PM
10/14/15 01:54 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I happen to like the vent windows in my '87 D100 and cannot think of a good reason to remove them.
Even in the '86 Ramcharger racer, it would be an easy way to get my time slips. Why change something just because you can???
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Vent Window Delete? [Re: TrxR] #1932035
10/14/15 03:07 PM
10/14/15 03:07 PM
Guitar Jones Offline
I've never seen it done. Anything can be done but re-engineering the entire door infrastructure, custom glass and regulator would certainly not make it a worthwhile endeavor.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Vent Window Delete? [Re: TrxR] #1932324
10/14/15 10:58 PM
10/14/15 10:58 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
It can be done. You will need additional piece of window track from a donor truck. Alignment is critical since you don't want any binding. I did this on a '65 Dart. Took a few times but I got done. A rodder friend suggested a power window kit.
Re: Vent Window Delete? [Re: TrxR] #1934662
10/19/15 02:46 AM
10/19/15 02:46 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
Custom glass=$$$
They make one-piece glass for 70s-80s Chevys now. Maybe you could adapt those.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
