Holley Hydramat
#1934597
10/19/15 12:58 AM
10/19/15 12:58 AM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Any of you guys use a Hydraamat pickup in your corner carvers yet? There was a lot of hype when they first came out so I was wondering if anyone has one yet. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Holley Hydramat
[Re: fourgearsavoy]
#1935339
10/20/15 12:58 AM
10/20/15 12:58 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Carl-
Please inquire if there will be a hydramat for direct walbro attachment. That would make things more interesting for sure. Thanks!
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Holley Hydramat
[Re: Kern Dog]
#1935709
10/20/15 06:36 PM
10/20/15 06:36 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My guess is that the stiff price will scare many people away. Stiff? You mean disturbing price.
Re: Holley Hydramat
[Re: Uhcoog1]
#1938002
10/24/15 10:52 PM
10/24/15 10:52 PM
fourgearsavoy
Rittman Ohio
Carl-
Please inquire if there will be a hydramat for direct walbro attachment. That would make things more interesting for sure. Thanks! Now that is really interesting,just drop it in the tank with a pump hanger and sender Gus
Re: Holley Hydramat
[Re: fourgearsavoy]
#1938704
10/26/15 01:07 AM
10/26/15 01:07 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Here is a question for those are more knowledgable on this subject. What would the advantage be of the hydromat over a pump like the Stealth 340 unit or making a sump with trap doors?
Carl Kessel
Re: Holley Hydramat
[Re: CKessel]
#1938864
10/26/15 12:11 PM
10/26/15 12:11 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Simplicity of installation, if it performs as promoted, effectiveness, and lastly, ability to extract the tank nearly dry, IMO.
Re: Holley Hydramat
[Re: fourgearsavoy]
#1940029
10/28/15 12:22 AM
10/28/15 12:22 AM
CKessel
Los Osos, Ca
So with something like the hydromat, you don't need to get carried away with baffling or sumps etc? You can do just a wide open tank? I'm getting some schooling on GTAW [tig] welding and I have most of the equipment needed to make one. I'm going to mini tub my car which will run the springs against the existing tank so the plan is to make one narrower and deeper. It will have the pump mounted inside. If the hydromat is the ticket instead of the Stealth pump, Vaporworx etc I'll go that direction.
Carl Kessel
Re: Holley Hydramat
[Re: fourgearsavoy]
#1940032
10/28/15 12:28 AM
10/28/15 12:28 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I like the idea of the Hydramat but it is more expensive than I wanted it to be lol.
I emailed Holley a few times about horsepower rating and they said none of the sizes are rated for HP but just to get the biggest one I could fit. Because of the vague answer I am just going to sump my tank and run a pair of Walboros behind it on bottom of the trunk floor.
68 Barracuda Formula S 340
Re: Holley Hydramat
[Re: Bad340fish]
#1940444
10/28/15 03:42 PM
10/28/15 03:42 PM
Uhcoog1
Houston Tx
So with something like the hydromat, you don't need to get carried away with baffling or sumps etc? You can do just a wide open tank? I'm getting some schooling on GTAW [tig] welding and I have most of the equipment needed to make one. I'm going to mini tub my car which will run the springs against the existing tank so the plan is to make one narrower and deeper. It will have the pump mounted inside. If the hydromat is the ticket instead of the Stealth pump, Vaporworx etc I'll go that direction. That's the idea. The original application is ARCA circle track cars (700 hp on gasoline). The hydramat covers the entire floor of that fuel cell. The videos show that if even a corner of the hydramat is covered in fuel, then it's still delivering. I just bought a tanks inc EFI tank ($500-$650 with everything). I'm running it with the walbro 460 lph e85 pump. I'll find out how it does at COTA in December. If it doesn't perform up to snuff, a small hydramat in the fuel tray would be perfect IMO. We'll see how it does before I try that, though. MUCH cheaper than the other options on the market, and well worth it even if I have to do a thing or two to get steady fuel pressure at 1/4 tank. I'll report back once I have more data. The ultimate is still the vaporworx as far as I can tell. both in price ($2200) and application. Depending on your power level, a gen 5 camaro, gen 5 camaro ZL1, or 2010-2014 CTS-V pump would be ideal. I like the idea of the Hydramat but it is more expensive than I wanted it to be lol.
I emailed Holley a few times about horsepower rating and they said none of the sizes are rated for HP but just to get the biggest one I could fit. Because of the vague answer I am just going to sump my tank and run a pair of Walboros behind it on bottom of the trunk floor. They are not hp rated, though it sounds like there is a limit. I found a guy running a small hydramat with two 460 lph pumps on a ~800 awhp evo, and the hydramat couldn't keep up. Course, that's a ridiculous amount of fuel. The guy theorized that the pumps were 'too much' for the hydramat material to retain surface tension that normally keeps the exposed areas of the hydramat from sucking air. Holley didn't have an answer for him at the time. So the two data points: ARCA - 12-873 Holley pump with 12-925 Hydramat - 160 gph - GTG 800+ awhp Evo - two Walbro F90000267 460 lph (each) with small hydramat - 200+ gph - NOT gtg Here is the link from his experience. It's a dead link - maybe someone can find it on their new site? http://www.boostedforum.com/Thread-Holley-Hydramat-doesn-t-work-as-advertisedHe was using this walbro adapter: https://www.radiumauto.com/Fuel-Pump-Inlet-Adapter-Kit-P565.aspx
Re: Holley Hydramat
[Re: fourgearsavoy]
#1942598
10/31/15 11:41 PM
10/31/15 11:41 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Thanks. The odd shape is just to stay within the flat sections of floor. it's 3/4x3/4 square tube. I'd probably go to 1x1 if I did it again for more clearance to the wire connections but this works just fine. The picture isn't with the tank fully tight but it fits well. The top piece is just some 16g sheet metal held down with drill screws. As always, more than one way to do something.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Holley Hydramat
[Re: fourgearsavoy]
#1942974
11/01/15 02:07 PM
11/01/15 02:07 PM
CKessel
Los Osos, Ca
Has anyone else run the Phantom setup with some hard cornering or auto x yet? Like most, I'm looking for the best, least costly hopefully, setup. Don't want to get into a mega buck setup like the Vaporworx system.
Carl Kessel
Re: Holley Hydramat
[Re: fourgearsavoy]
#1948793
11/10/15 03:42 PM
11/10/15 03:42 PM
CKessel
Los Osos, Ca
I had the chance to talk to the Holley rep at the show and got a very cool demo on the unit. Very impressive. Also the new Hot Rod magazine has an article towards the back of the issue with some more info. When I get a chance, I'll dig through the 2 milk crates worth of info I picked up and add some more information to this. One thing, yes its not cheap, but its less than spending big coin on a fabbed and heavily baffled tank. Pick your poison.
Carl Kessel
