Preparing 70 RR Grille for repaint - Thoughts? #1933774
10/17/15 01:48 PM
10/17/15 01:48 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
My 70 RR grille has a previous repaint that is peeling a bit. I want to repaint it, but should remove the previous repaint first. What are some recommended options to remove this paint?
Re: Preparing 70 RR Grille for repaint - Thoughts? [Re: BPBP440] #1933811
10/17/15 03:36 PM
10/17/15 03:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Heated pressure washer, 400 sand paper and water.
Re: Preparing 70 RR Grille for repaint - Thoughts? [Re: Challenger 1] #1934036
10/18/15 12:15 AM
10/18/15 12:15 AM
BPBP440 Offline OP
BPBP440  Offline OP
Anybody used a media blaster for this? The media I currently have access to is too rough I'm sure. Thoughts?
Re: Preparing 70 RR Grille for repaint - Thoughts? [Re: BPBP440] #1935302
10/19/15 11:53 PM
10/19/15 11:53 PM
BPBP440 Offline OP
BPBP440  Offline OP
Anyone else?
Re: Preparing 70 RR Grille for repaint - Thoughts? [Re: BPBP440] #1935613
10/20/15 03:57 PM
10/20/15 03:57 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Rough media would be bad. the right paint has the roughness in it. The pressure washer is great, need to hold it down so it doesn't fly away when hitting it with the pressure.
blowing with compressed air may remove the paint also. you need to experiment to see what works best on it.
Re: Preparing 70 RR Grille for repaint - Thoughts? [Re: BPBP440] #1936369
10/21/15 09:20 PM
10/21/15 09:20 PM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
Even with a power sprayer you got to be careful with 45 year old plastic parts. I don't know what the best way would be. But I would probably start with something fairly gentle.
Re: Preparing 70 RR Grille for repaint - Thoughts? [Re: BPBP440] #1937217
10/23/15 11:38 AM
10/23/15 11:38 AM
O
otter440 Offline
otter440  Offline
O
I have done a number of grilles I use glass beads and be careful and cabinet blast and wash with spray nine dry and paint works great
Re: Preparing 70 RR Grille for repaint - Thoughts? [Re: BPBP440] #1937906
10/24/15 07:50 PM
10/24/15 07:50 PM
BPBP440 Offline OP
BPBP440  Offline OP
Thanks for the thoughts everyone.
