Tick, tick, tick, tick #1932861
10/15/15 10:45 PM
10/15/15 10:45 PM
Mid Michigan
Coronet-R/T-Rag Offline OP
Mid Michigan
Fresh 440. Stealth heads. Comp hydraulic Xtreme Energy™ Hi-Lift XE275HL. It has ticks that will not go away! It's louder than the solid lifter cam I ran in my last 440. I've changed springs. I tried different anti-pump lifters. I tried different preload with crane adjustable valvetrain. I even pulled the adjustable and tried the factory pushrods and rockers. The noise seems to come from the middle of both valve covers. What am I missing? Could it be a cam bearing not aligned properly? I doubt I'll be able to sell the car when I'm ready soudning like this.
Re: Tick, tick, tick, tick [Re: Coronet-R/T-Rag] #1932865
10/15/15 10:49 PM
10/15/15 10:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Got a windage tray? Could it be hitting a rod bolt?
Maybe a TC bolt backed out a bit and is just kissing the block.
You absolutely sure it's valve train related? Have you pulled the valve cover and listened to each rocker with a stethoscope to narrow it down?
Don't be the exception.
Re: Tick, tick, tick, tick [Re: Coronet-R/T-Rag] #1932875
10/15/15 11:01 PM
10/15/15 11:01 PM
Mid Michigan
Mid Michigan
I've got a windage tray but I'm sure this is valvetrain noise. I've checked the TC bolts and they are tight. From what I've read on other posts, these cams are loud. I'm just a little flabbergasted at how loud. I've got headers (that i've pressure tested for leaks) and quite exhaust. The engine makes great power and I'm very happy with all but the ticking.
Re: Tick, tick, tick, tick [Re: Coronet-R/T-Rag] #1933045
10/16/15 02:53 AM
10/16/15 02:53 AM
I ain't run into this myself but the Moparters here say that a header leak can sound just amazingly similar. Any chance it could be pin/lock related? I would do what Supercuda said & breakout the stethoscope. Holler how it turns out. EDIT always done it since breakin/new
Re: Tick, tick, tick, tick [Re: RapidRobert] #1933803
10/17/15 03:12 PM
10/17/15 03:12 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Originally Posted By RapidRobert
I ain't run into this myself but the Moparters here say that a header leak can sound just amazingly similar...
I can confirm that...had that exact situation once, I was using the SB headers which have a short run of one of the primary tubes slide into the remaining tube...eventually, somehow, I got a leak there...no crack, just corrosion I suppose (car was used during Canuck winters, lots of road wear)...I took me some time to figure that one out.
Also had the TC issue as well. One of the bolts backed out enough to just nick, we are talking barely a touch, the dustshield cover...once I pulled the inspection cover and had a look at all the bolts it was easy to tell though.
Re: Tick, tick, tick, tick [Re: Coronet-R/T-Rag] #1933976
10/17/15 10:53 PM
10/17/15 10:53 PM
MD
p d'ro Offline
p d'ro  Offline
MD
My exhaust manifolds keep doing this even after buying Remflex gaskets. Mine are a major pain to change on 67 rt ragtop. Good luck.
