undercarriage frame paint/rust protection choices? #1933238
10/16/15 02:48 PM
10/16/15 02:48 PM
usa
smos001 Offline OP
smos001  Offline OP
usa
Thinking about scrubbing down the frame rails etc on the underside of the Challenger and coating/painting the metal.
What is the best for protecting the underside of the car? PUR15? paint?
Rubberized spray?
How do you guys prep?: de-grease? Rust encapsulate spray?
Smos
Re: undercarriage frame paint/rust protection choices? [Re: smos001] #1933404
10/16/15 08:16 PM
10/16/15 08:16 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Anything that labels itself as a rust encapsulator is crap IMO.
Best? Sandblast bottom of car, epoxy prime and undercoat. If sandblasting is not an option I would use a diesel fired hot water pressure washer. That would take most down to bare metal, whatever's left you could hit with a wire wheel on a grinder, then rewash and epoxy prime.
Re: undercarriage frame paint/rust protection choices? [Re: DaytonaTurbo] #1933439
10/16/15 09:01 PM
10/16/15 09:01 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
iagree
Re: undercarriage frame paint/rust protection choices? [Re: Challenger 1] #1933495
10/16/15 10:28 PM
10/16/15 10:28 PM
USA
hudsonhornet7x Offline
USA
iagree
I agree with these fellas
Re: undercarriage frame paint/rust protection choices? [Re: smos001] #1933893
10/17/15 07:47 PM
10/17/15 07:47 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I spent almost the entire summer under my 'Cuda with a torch and scrapper. Got it clean as a babies but. Then sprayed it with Hammerite. Thats some tough stuff. Ain't no easy way to do it.
Re: undercarriage frame paint/rust protection choices? [Re: Cudajon] #1933900
10/17/15 08:01 PM
10/17/15 08:01 PM
Cincinnati, Ohio
Cincinnati, Ohio
Dude I have to say, I spent 4 hours one afternoon and had a bare bottom, clean enough to eat off of when I removed undercoating...3 cars so far. I used a steam pressure washer, it's tons easier and better than a torch. Rent one, it's worth it for this job and get your car done this decade.
And entire summer just removing undercoating? eek
