Re: CD with not play or eject
[Re: MLR426]
#1933604
10/17/15 12:57 AM
10/17/15 12:57 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Never seen your head unit in particular, but a lot of CD players have the manual eject that Rhinodart describes. Look for a tiny unmarked hole in the front and straighten a good stiff paperclip and insert it. On the ones I've done It isn't like pushing a button and the cd pops out, it is more like working a tiny lever inside until the tray is far enough out to grab hold of.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: MLR426]
#1933606
10/17/15 12:58 AM
10/17/15 12:58 AM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
hammer
then have the ins company buy you a new one.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: MLR426]
#1933658
10/17/15 03:04 AM
10/17/15 03:04 AM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
Get the cd out as described, pull the head unit out, take the case apart.
Expose the "eye" reader for cds, it will be obvious and should have an access port. Dip a Q-tip in alcohol and clean the eye with it. Wipe it dry. Put it back together.
Done it many times to aftermarket and factory cd players and it works everytime.
If this doesn't work, throw it away and get a new one or a replacement from the autowrecker: they are not worth sending out for mechanical repairs.
Mo' Farts
Moderated by "tbagger".
[Re: MLR426]
#1938919
10/26/15 02:07 PM
10/26/15 02:07 PM
Posts: 3,141 tennessee,usa
mattsmopars
tennessee,usa
Had to replace the radio/CD player in my 2003 ram the other day for about the same reason. It would not pull the cd in far enough to play it some time and would not eject it all the way. I would have to peck on the dash to get it all the way in or out. Bought a re-man unit off eBay to replace it with. Matt
[Re: MLR426]
#1938960
10/26/15 03:16 PM
10/26/15 03:16 PM
Posts: 6,008 Salem
Grizzly
Salem
It sounds alot harder than it really is, Guys.
Just take it apart, and go to it. They are still mechanical components and just a dab of grease on the eject gears, and some alcohol wipe on the eye and they work like new.
Done many of them, never more than an hour or two to get them working again.
Mo' Farts
[Re: MLR426]
#1939383
10/27/15 12:29 AM
10/27/15 12:29 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Common problem, especially if its a multi disk unit. It will have to be pulled and sent in for exchange. BUT...when you get your discs back, if you get them back, they will most likely be trashed by the repair center. You will want to speak with the service manager about getting reimbursed for the damaged/missing discs before you pull the trigger. The main hickup in this is ma mopar. You might be ahead of the game if you put a call in to the customer relations number to squawk farther up the food chain to help getting reimbursed. When I worked at the dealer, the manager at the time made things happen for the customer. He knew who to lean on at Dodge corporate. Now its like TSMF at the dealers because mopar tries to be egyptian [ living in denial] about problems with the cars and put it off on the dealers to give you the good news because its easy for them, mopar, to deny coverage when they are not the ones looking you in the eye.
Carl Kessel
