Re: Which seal for disc front brakes?
[Re: tman]
#1932459
10/15/15 04:58 AM
10/15/15 04:58 AM
Posts: 216 E. Okla line
m88mark
E. Okla line
Im told that the 10 and 11" bearings are the same for drums and disc. Now the seal is a mystery. Even the catalogs say bearings for 10 and 11 inch brakes are the same, but no mention of disc brakes. Hope someone knows which seal is correct. Don't want to buy both sizes. Cass has the wear rings bearings & seals!
[Re: tman]
#1932485
10/15/15 10:06 AM
10/15/15 10:06 AM
Posts: 601 Mass
charge70
Mass
Have a 70 Cuda with front disc brakes. Will be changing rotors during winter. I found the correct inner and outer bearings, but mixed up on which seal is correct. All the parts guides that I can find including Rockauto show different seals for 10 inch or 11 inch brakes. Does not say which one for disc brakes. So for those that know, which seal is correct? Please give a brand and part#. Thanks. The seal for 11" drum brakes is correct for disc brake rotors. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
