Re: Hoooking up throttle to Edelbrock Carb
[Re: Supercuda]
#1932189
10/14/15 07:32 PM
10/14/15 07:32 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Here's what the linkage looks like when connected.
[Re: Pynzo]
#1932218
10/14/15 08:23 PM
10/14/15 08:23 PM
Posts: 10,741 North Dakota
6PakBee
North Dakota
All you need is the throttle stud then. I drilled out the top hole in my Edelbrock lever (#4 in your pic) and it worked fine with the stock stud and cable. You need the throttle return spring bracket also. Mounts under front mani bolt. Check the above diagram. You can also drive out stud #2 in your pic you won't need it with a 4 speed. I just did this on a '69 GTS 340 automatic. If you don't use the Edelbrock adapter the throttle stud is too far to the center of the engine and puts the throttle cable in a bind. Again, this was an automatic.
[Re: BigAg]
#1932259
10/14/15 09:57 PM
10/14/15 09:57 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Looking at your pic again I see that you do not have a spacer between the manifold and carb. Edelbrock has many to choose from check their website. You'll want to add one before you fire it up. There are too many posts on this site trashing and hailing that carb. Use the search function to learn as much as you can about it. And move your Accelerator Pump Rod to the middle hole.
[Re: BigAg]
#1932261
10/14/15 09:58 PM
10/14/15 09:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I couldn't tell if it was a stick or not, no kickdown needed on a stick obviously, but as mentioned, without the adapter the cable is in a funky angle to the linkage. If you chose to not use the adapter then make sure the throttle opens completed with the pedal to the floor.
[Re: Car Nut]
#1932428
10/15/15 02:27 AM
10/15/15 02:27 AM
RapidRobert
move the pump rod to the middle hole last as all the pumping for this mockup to take care of this will dump raw feul into the eng for no good reason. Not a dealbreaker but its my OCD talkin EDIT in fact unhook it as soon as you start messing with this
