Add on Gauge Cluster mounting locations #1931792
10/14/15 12:46 AM
10/14/15 12:46 AM
FL
HelleOnWheels Offline OP
FL
I have a 67 RT and am wanting to add a volt meter at a minimum or maybe a typical oil/water/volt cluster. Should i do the 3 cluster or just add the volt only? Either way.....any pics of where you guys mounted add on gauges?
Re: Add on Gauge Cluster mounting locations [Re: HelleOnWheels] #1931862
10/14/15 02:51 AM
10/14/15 02:51 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Since I do not smoke, I removed the ashtray and made a plate to mount 2 guages there.
Re: Add on Gauge Cluster mounting locations [Re: Kern Dog] #1932206
10/14/15 08:08 PM
10/14/15 08:08 PM
IN
ahy Offline
ahy  Offline
IN
I made a plate for the radio hole for a mechanical OP gauge (no radio). Could fit at least 2 gauges there.
Re: Add on Gauge Cluster mounting locations [Re: ahy] #1932317
10/14/15 10:50 PM
10/14/15 10:50 PM
Indiana
Y
YO7_A66 Online content
YO7_A66  Online Content
Y
Indiana
I don't use my glove box so I put two gages in there. When I need to see them, I just pop open the door.
Re: Add on Gauge Cluster mounting locations [Re: HelleOnWheels] #1932389
10/15/15 12:37 AM
10/15/15 12:37 AM
FL
FL
thanks for the replies.....i really like the idea of removing the ashtray and installing them in there. I may have to try that out
