Re: Primer or filler first
[Re: moparmikethree]
#1931808
10/14/15 01:05 AM
10/14/15 01:05 AM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Many schools of thought on this but I always put filler over a good etching primer like DP-90. I know its somewhat old school but filler is porous and will absorb moisture from the air. If you leave it long enough the primer will trap moisture in the filler and it will eventually rust from the inside out. That's just the way I learned to do it.
Some people swear its better to put the filler over bare metal and they have good reasons that make sense to them. I just prefer to put it over a good etching primer so the metal is sealed from the environment first.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
#1931891
10/14/15 08:57 AM
10/14/15 08:57 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Another vote for epoxy primer first. Strip the car to the best of your ability, I then treated the bare metal, then shot epoxy, then started filler. Any dent work or metal work is done first, then epoxy then filler. Just the way I have done 3 cars. Mainly tutored by people here and autobody101 webpage and forums plus a great paint salesman who goes to PPG schools and shares their method applying their products.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: moparx]
#1932548
10/15/15 12:23 PM
10/15/15 12:23 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I am not aware of any true 2 part epoxy spray cans, be interesting to hear about though. I would lean towards a DTM epoxy under filler, instead of a self etch, and I really like self etch in rattle cans for ease of us. I wonder if OP has a limitation on spraying epoxy primer, why couldn't he just brush it on, if its going under filler?
[Re: jcc]
#1932604
10/15/15 02:08 PM
10/15/15 02:08 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I am not aware of any true 2 part epoxy spray cans, be interesting to hear about though. I'm not a big user of spray bombs, but Tower paint in Wisconsin has supplied me with some unique paint products/opions in spray bombs over the years, any paint product/mfg can be supplied thru them in spray can Mike
[Re: jcc]
#1932990
10/16/15 01:27 AM
10/16/15 01:27 AM
Posts: 20,559 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I use a Preval sprayer for small primering jobs. I have applied single stage urethane paint to engine blocks and heads with them as well. Very cheap and you can find them at pretty much any hardware store. Once you use one a couple times you get a feel for how much material you'll need in the jar to cover whatever it is your painting and you can get to where there is very little waste. Run some reducer thru the sprayer when your done and you can reuse them until the propellant is used up. If you don't clean them the paint dries inside and it's game over. http://preval.com/
#1933174
10/16/15 12:31 PM
10/16/15 12:31 PM
Posts: 1,541 USA
hudsonhornet7x
USA
I can understand the ease of use for the 2k aerosol, but if there is a decently large ares ( Footbal size or bigger ) I believe a true 2k epoxy would be best , if for no other fact than mill ( thickness) build.
I prefer Southern polyurethanes epoxy, and just mix what I need at that moment in time.
As far as restoration work- 1. Sandblast 2. Clean. 3. Clean again 4. Epoxy 5. Filler work after 24hrs of epoxy drying.
