Re: a real crazy problem
[Re: scottk]
#193151
01/14/09 11:30 AM
01/14/09 11:30 AM
Posts: 15,487 Florida
scratchnfotraction
start from scratch top dead center on # 1 and look at timing mark on damper and then look at dist and see where its pointing then wire it from there the chain could have jumped and be rewired the dist could be out a tooth as well if its been out
[Re: scottk]
#193153
01/14/09 11:55 AM
01/14/09 11:55 AM
RapidRobert
as Scratch said. 1 5 3 6 2 4 is correct & will work. what's causing the problem is your not starting #1 plug wire in the right dist socket. EDIT just make sure you start at #1 compression when you have the marks at TDC. & with those readings you have a pretty healthy long block! timing chain is not jumped.
[Re: RapidRobert]
#193154
01/14/09 12:27 PM
01/14/09 12:27 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I agree. Your compression test suggests that cam timing is correct.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: mt162]
#193156
01/14/09 01:33 PM
01/14/09 01:33 PM
RapidRobert
from 1967 "glenns" manual
[Re: RodStRace]
#193158
01/14/09 05:52 PM
01/14/09 05:52 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
Sounds to me like you need to start over from scratch getting it on TDC. Then go from there.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
