Re: The `Cuda rumbles again!
[Re: RylisPro]
#1931302
10/13/15 10:50 AM
10/13/15 10:50 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Awesome on the seat. And running with the STI!
Oh the racepac- plug in your tuning laptop and see if the tunerstudio gauges go dead at the same time. It'll help narrow down where the wiring issue is.
Also- radiator hoses- in mine I have to run the clamps pretty darn tight to keep from leaks, especially on the lower hose. And the closer you clamp to the rib without being on top of the rib, the better.
AN oil fittings- tighten that sucker down HARD before you replace it. Works on mine. The only leaks I've had that required more than that were NPT.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: RylisPro]
#1931303
10/13/15 10:51 AM
10/13/15 10:51 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you end up running two clamps per connection make sure you off set them 180 degrees.
[Re: RylisPro]
#1931374
10/13/15 01:41 PM
10/13/15 01:41 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
My lower hose has 2 clamps at every connection. Seems these things pump some stupid pressure, also have a 30# cap.
Mopar to the bone!!!
[Re: 72Swinger]
#1931723
10/13/15 11:09 PM
10/13/15 11:09 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Not sure of your cooling status, but wouldn't that be a sign of starting to look at an underdrive pulley combination?
[Re: RylisPro]
#1934324
10/18/15 03:56 PM
10/18/15 03:56 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
Its good to hear your car running! I'm so close it's driving me nuts...
have you tried the gates heat shrink clamps, they work really well.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=gates+power+grip
[Re: ntstlgl1970]
#1934325
10/18/15 03:57 PM
10/18/15 03:57 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=gates+power+grip clicky linky > clicky here
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: ntstlgl1970]
#1934410
10/18/15 06:56 PM
10/18/15 06:56 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Thanks ntstlgl1970! I should have gotten those clamps in the first place! I pretty much fixed the leak issues just tightened my clamps down all the way. Just make sure you have the correct crank sensor and plug all the vaccuum ports!
[Re: RylisPro]
#1943934
11/02/15 09:22 PM
11/02/15 09:22 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Car has been running good so far. I was able to fix my IQ3 dash issues by wiring it directly to a 12 volt source. I also fixed my hot starting issues. I actually had a 2 gauge positive cable to the trunk mounted battery and replaced it with a fat 1/0 gauge welding wire. Car starts right up when hot. I did notice a minor oil drip leak from the oil pan port where the temp sensor is but that's an easy fix. I also drove the car for about an hour straight yesterday around East Bay area. I do drive the car to and from work but it is only a 15 min drive and not enough time to burn up the crap and by-products produced in an engine. I drove about 85-90 miles from Concord to Hayward up past Oakland and Berkeley back home. I was doing about 80 mph and only used about a quarter of a tank of gas. I have a 22 gallon cell so that was only about 5.5 gallons for 85-90 miles which is about 15 MPG. Coolants temps were good too averaging around 195*F. I still need to get the car weighed and am curious to see if there is any significant weight loss.
[Re: RylisPro]
#1946635
11/06/15 10:57 PM
11/06/15 10:57 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I went to my local truck scale today after work. This is the same truck scale I went to last year with the old 340 engine and half a tank of fuel. Car weighed 3580 lbs. back then. Only major things I did was cut out the door beams and swap in the aluminum engine. I found that the truck scale is not that accurate as it measures in 20lbs. increments. Here is the weight. The first pic says 3500, second is 3480, so I would say the cars weight is about 3490 lbs. I weigh about 140 lbs. and I have about 10lbs. of crap in the trunk. 3490-150 = 3340 Car weighs approx. 3340lbs. with about 11 gallons (1/2 tank) of fuel.
