road runner door switches #1929960
10/11/15 01:00 AM
10/11/15 01:00 AM
Colorado Springs,Colorado
Roadrunner440-6 Offline OP
In a 1970 roadrunner....Is the trunk light switch (in the trunk) the same as the door jamb (dome light) switches? Any help will be greatly appreciated. Thanks
Re: road runner door switches [Re: Roadrunner440-6] #1930056
10/11/15 10:33 AM
10/11/15 10:33 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
No.
But the trunk switch is the same as the park brake switch
Re: road runner door switches [Re: Roadrunner440-6] #1930135
10/11/15 01:06 PM
10/11/15 01:06 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Left switch is the Parking Brake Switch and right is the Trunk Lamp Switch from a '70 Coronet. Trunk Switch should be cad or zinc plated. I Parkerized mine trying to keep it alive as it was rusty. Couldn't help as the inner spring broke. Anyone have a part number?
Re: road runner door switches [Re: Pynzo] #1930291
10/11/15 05:39 PM
10/11/15 05:39 PM
Thanks guys! Good info
