Electrical fix?
#1929864
10/10/15 10:44 PM
10/10/15 10:44 PM
moparpollack
Lil Herman
Lil Herman
85086
How would you fix a wiring harness that had the ammeter terminals cut off two inches from the ammeter terminals?
Solder on new ends? Crimp new ends? Add new wires to the terminal plug?
Re: Electrical fix?
[Re: moparpollack]
#1929932
10/11/15 12:07 AM
10/11/15 12:07 AM
RapidRobert
Solder on new ends? Add new wires to the terminal plug? No big deal either way. solder on new ring terminals If you have 2 quality ones handy, if not then solder in 2 lengths of wire to connect the OE insulated ring terminals with pigtails (sounds like they're still there) to the red and black wires. clean the wires/terminals with brake kleen before soldering as you need good connections there. #1 caveat, always pull a batt cable before doing ANY electrical procedures
Re: Electrical fix?
[Re: moparpollack]
#1930106
10/11/15 12:34 PM
10/11/15 12:34 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
FWIW - I always stagger my soldering joints to reduce the chance that they would ever contact each other (zoom in on photo). I double heat-shrink each joint as well. IMG_5975 by R M, on Flickr
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Electrical fix?
[Re: moparpollack]
#1930163
10/11/15 02:03 PM
10/11/15 02:03 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
The proper way is to use a non insulated butt terminal and crimp it, followed by soldering both ends, then heat shrink tube it. You never want to rely upon a solder joint to hold a two wires together, especially wires running voltage and amperage between the alternator and battery. The heat generated in a short situation is more than enough to melt that solder joint and shrink tube. Now you e got a bare hot wire under your dash. Wheeee! Do the same with the end terminals. Bare terminal, crimp, solder, shrink tube.
I’m listening.
Re: Electrical fix?
[Re: Big Bad Bee]
#1930174
10/11/15 02:14 PM
10/11/15 02:14 PM
RapidRobert
The proper way is to use a non insulated butt terminal and crimp it, followed by soldering both ends, then heat shrink tube it. Do the same with the end terminals. Bare terminal, crimp, solder, shrink tube. Ding ding ding I do believe we have a winna!
