Repop. Upper Control Arms? #1929591
10/10/15 01:29 PM
10/10/15 01:29 PM
Cincinnati, Ohio
superbeedave Offline OP
Cincinnati, Ohio
Hey all, Been a while since my last post. Looking to buy a new pair of the reproduction Upper control arms with the ball joints already installed on them for my 69 Bee. Who should I buy from to make sure they will fit properly and are not more that $150.00 a pair? Also how can I get the caster and camber close enough to be able to drive it to the alignment shop? Thanks, Dave
Re: Repop. Upper Control Arms? [Re: superbeedave] #1929836
10/10/15 10:13 PM
10/10/15 10:13 PM
IN
ahy Offline
ahy  Offline
IN
Not sure on where to get the control arms... Mancini carries them, good place to look first.
As far as alignment, just need to get the toe close. Driving a short distance with camber and caster off should not hurt anything.
Re: Repop. Upper Control Arms? [Re: superbeedave] #1929899
10/10/15 11:28 PM
10/10/15 11:28 PM
GA
roadrunninMark Offline
GA
Re: Repop. Upper Control Arms? [Re: roadrunninMark] #1929969
10/11/15 01:11 AM
10/11/15 01:11 AM
None
71rm23 Offline
71rm23  Offline
None
Many carries them from different vendors. I got mine from Firm Feel
Re: Repop. Upper Control Arms? [Re: superbeedave] #1930003
10/11/15 02:46 AM
10/11/15 02:46 AM
WA
tman Offline
tman  Offline
WA
Do these look the same? Part numbers sure look the same.....
http://www.ebay.com/itm/70-74-E-Body-Upp...883&vxp=mtr
http://www.ebay.com/itm/MOPAR-Control-Ar...c6f&vxp=mtr
And there are prices in between.
Re: Repop. Upper Control Arms? [Re: superbeedave] #1930042
10/11/15 09:33 AM
10/11/15 09:33 AM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks guy's, How could one set from one dealer on Ebay be $256.00 and
another one from a different dealer be $110.00 when they appear to be the same?
Re: Repop. Upper Control Arms? [Re: superbeedave] #1930051
10/11/15 10:10 AM
10/11/15 10:10 AM
IN
ahy Offline
ahy  Offline
IN
Whoever invested in the tooling to stamp the new arms likely makes them for several companies... though specs and QC may vary including quality of ball joints and bushings. I would personally prefer to trade with Mancini or Firm Feel on a part like this.
If you want to keep cost down, I have a clean used set from a '70 California E. They are stripped and bare. Screw in the ball joints, press in the bushings and go. Send a PM if interested.
