Well, that was ...........weird
#1929392
10/10/15 12:34 AM
10/10/15 12:34 AM
Posts: 16,811 Between Houston & Galveston TX
SattyNoCar
So, I was on my way home from work this evening in my '93 Dakota when something new and weird happened. It started to whine. It sounded almost like a blower whine. Did it probably less than a minute, but, while it was making the noise, the truck got super responsive, and the tach suddenly seemed to be reading correctly. None of the other gauges showed any different. Noise stopped, truck went back to 'normal', and the tach went back to its usual reading off in la-la land. Whiskey Tango Foxtrot? Any ideas? Sudden burst of juice from the alternator? Didn't have time tonight to really look at it, but, a quick underhood glance didn't show anything out of place.
John
Re: Well, that was ...........weird
[Re: Kern Dog]
#1929475
10/10/15 09:51 AM
10/10/15 09:51 AM
SattyNoCar
That was the first thing I thought of too as my junk usually runs its best just before it dies. But, on a serious note, I don't understand the correlation between how the tach is (or isn't) working and how the truck is running. As I've mentioned before, if the tach is basically flat line and not working, the truck has no 'snap'. It almost feels like the brakes are dragging. If the tach is working, even though not accurately, the truck has 'snap'. This whining incident seemed to be an extreme example of this. Where do I begin to trouble shoot? It seems to be electrical related, start with the harness and work my way out checking the alternator and computer too?
John
[Re: dogdays]
#1932391
10/15/15 12:40 AM
10/15/15 12:40 AM
SattyNoCar
It made the noise again tonite. This time I was able to quickly stop and get underhood to listen to where it was coming from...... The alternator. Same scenario as before, responsive, tach working..etc, etc. OK, so the alternator maybe going bad, but, what exactly is happening to cause the other issues?
John
[Re: SattyNoCar]
#1932407
10/15/15 01:16 AM
10/15/15 01:16 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Low voltage does some weird stuff... I had a bad alternator cause my aftermarket tach read funny... It could be your cause period.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
