paint guys, need a little help #1929221
10/09/15 07:37 PM
10/09/15 07:37 PM
California
mickm Offline OP
mickm  Offline OP
California
so i have a HVLP gun that i'm going to use to spray acrylic enamel onto the engine block.
i've used a gun before, but always doing furniture, so i do know how to spray. paint, on the other hand, is a new thing, as well as setting up and using the gun specific to paint.
so, basic questions:
1 - stir paint well, pour through strainer into container. stir reducer well, pour equal amount through strainer into container. how long can this mixture sit around before it is no good?
2 - how long between coats?
3 - i have a (not sure of the term) water separator that goes between the air compressor and the gun. there are very little instructions with it, but it does say something about oil???
4 - it also has a valve to regulate outgoing pressure, but no gauge, how do i know where to set that?
5 - after using, clean cup on gun out with lacquer thinner, then spray though gun until clean. anything else?
basically, all the tips you can give will be appreciated, as this is all brand new to me.
thanks!
Re: paint guys, need a little help [Re: mickm] #1929330
10/09/15 10:53 PM
10/09/15 10:53 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
How I would do it:
Paint and reducer into mixing cup. Stir thoroughly to combine. With no gloss additive or catalyst, this mixture is good until it evaporates all the solvent. Strain before it goes in gun.
Depending on air temp and solvent speed, probably 10-20 minutes between coats. Check for it almost dry to the touch on some masking paper or tape.
Unless you have a water problem or humid day, a throw away filter on the gun is fine for that small of a project.
I hardly ever use a gauge. I ramp up until the paint atomizes well, and you get a nice 8-10" cigar pattern on some paper. Probably 35-40psi at the inlet
Clean thoroughly with lacq thinner. An old toothbrush can be helpful, but I always take the air cap and fluid nozzle off and soak those separately.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: paint guys, need a little help [Re: herkamer] #1929349
10/09/15 11:20 PM
10/09/15 11:20 PM
None
71rm23 Offline
71rm23  Offline
None
Originally Posted By herkamer
How I would do it:
What this member said
Re: paint guys, need a little help [Re: mickm] #1929468
10/10/15 09:31 AM
10/10/15 09:31 AM
crlush Offline
crlush  Offline
Most auto paint stores should have a regulator that screws to gun with a guage, harbor freight probably has them also. You get a pressure drop at the gun running thru the hose.
Re: paint guys, need a little help [Re: mickm] #1929476
10/10/15 09:53 AM
10/10/15 09:53 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Can you find a data sheet for your paint? These two will be listed on there as re-coat time and "pot life".
I second the HF regulator at the gun, I usually knock my air down near the compressor to get it close, then regulate it again right at the gun. Don't forget another cheapie gun-filter right at the gun. twocents
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: paint guys, need a little help [Re: GoodysGotaCuda] #1929484
10/10/15 10:16 AM
10/10/15 10:16 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Do yourself a favor and get a small gun cleaning kit at Harbor F.
cost a few dollars .
take the gun compleately apart to clean and relube with paint gun oil to prevent dried up paint and spray problems unless you are useing a throw away gun .
expensive guns will still trap small amounts of paint in the gun that will not come out by just spraying laqur thiner through.
I used to do that and My paint supply guy told me to take the gun apart and see if all paint was gone when i had finnished cleaning it that way.
Guess what not!
worse yet you may get a white paint job and ruin it with blue paint left in the gun from last job,I had it happen.
Take the gun apart compleatly if you want the gun to work for a long time.
1969 Dodge Charger 1969 Dodge Superbee
Re: paint guys, need a little help [Re: mickm] #1929534
10/10/15 11:50 AM
10/10/15 11:50 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I have the expensive guns and cleaning is an unavoidable chore...But lately I've bought the HF cheapy guns{as in 10 bucks with a coupon} and I'm impressed with the spray pattern coming out of them...Use them, clean them, or toss them...Heck I swear I use more lacquer cleaner on the good guns than what the cheapee gun costs !!! laugh2 primer
Re: paint guys, need a little help [Re: screamindriver] #1929654
10/10/15 03:55 PM
10/10/15 03:55 PM
California
mickm Offline OP
mickm  Offline OP
California
all good info, thanks guys.
i will get a cleaning kit. this isn't something i'll be doing all the time, so it makes sense to clean the gun well and have it around.
screamin, that's bizarre about guns being that cheap, and good enough to use. part of doing business with china i guess, is some stuff comes out for nearly nothing!
i should be doing it today or tomorrow, i'll let you know how it goes.
Re: paint guys, need a little help [Re: mickm] #1931144
10/12/15 11:16 PM
10/12/15 11:16 PM
California
mickm Offline OP
mickm  Offline OP
California
ok, didn't get to it. next weekend, maybe. hopefully.
next question:
is it ok to let the gun sit around for that 10 20 minutes between coats? will the paint dry in the nozzle or anything?
Re: paint guys, need a little help [Re: mickm] #1931293
10/13/15 10:13 AM
10/13/15 10:13 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
you will be fine.
perception is 90% of reality
Re: paint guys, need a little help [Re: Mr T2U] #1931346
10/13/15 12:44 PM
10/13/15 12:44 PM
California
mickm Offline OP
mickm  Offline OP
California
Originally Posted By Mr T2U
you will be fine.
