440 source 543 #1929206
10/09/15 07:20 PM
10/09/15 07:20 PM
High Plains of South Dakota
O
olwhite64 Offline OP
O
Anybody done one of these?
Pro's/Con's?
Re: 440 source 543 [Re: olwhite64] #1929237
10/09/15 08:01 PM
10/09/15 08:01 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Not that kit. Question would be what is the application for. Also What heads are you planning on using? It's easy to over cube the efficiency of the heads. The 4.250 stroke with the 7.100 rod fits really nice and horse power can be made in other area's than the additional stroke.
Re: 440 source 543 [Re: olwhite64] #1929243
10/09/15 08:13 PM
10/09/15 08:13 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
In my extremely less than novice opinion, a 4.5" arm in a stock block would put a lot of stress on it (especially a 440 that has a weaker bottom end than a 400). I'd think for a low rev motor it would be a nice kit. You'd want to under head it in that case.
Re: 440 source 543 [Re: olwhite64] #1929255
10/09/15 08:49 PM
10/09/15 08:49 PM
Renton Washington
Triple Threat Offline
Renton Washington
Good for a truck, not a good race motor in a stock block.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 440 source 543 [Re: olwhite64] #1929308
10/09/15 10:34 PM
10/09/15 10:34 PM
Pro's/Con's?
Whats the exact engine specs and application?
Re: 440 source 543 [Re: Cab_Burge] #1929315
10/09/15 10:42 PM
10/09/15 10:42 PM
For a 440 RB block: 4.500" stroke. 7.1" rods. I'm sorta considering one. I would need the extra wide flange #3 main bearing (for my later block) and I wanted file fit rings
Re: 440 source 543 [Re: olwhite64] #1929453
10/10/15 06:16 AM
10/10/15 06:16 AM
gregsdart Offline
gregsdart  Offline
I built a 535, 4.5 stroke, 4.350 bore. It made a ton of torque with 906 ported heads. It can be built into a great street motor because you can shift at 5400 or so and maybe less for best performance. I was shifting at 5700 with a 590 cam and I may have been over revving it. The nice thing about that many cubes is the ability of running a very tight converter and a low (3.23?) rear gear and it will still fly. The key to making it live is keep the revs way down and be conservative on the tune. They also make great bracket motors if you want a very low rpm reliable deal. I believe the torque peak using the McFarland formula would be about 3900 rpm. This is not a motor to push over 650 hp, or big port heads.
Re: 440 source 543 [Re: gregsdart] #1929459
10/10/15 07:40 AM
10/10/15 07:40 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have a 4.25 crank with the 2.20 BB Chevy Rod size and journals.
It's pretty close on the oil pump pickup (within .050) and it still easily clears the bottom of the bores with no issues.
I put together my own "kit" using Molnar crank, 7.1" rods and Mahle pistons. It balanced really nicely with just a little weight being removed from the crank. It was also cheaper than the source kit and utilized, IMO, better rods and pistons.
The Molnar stuff is very nice and dropped in with no fuss!
Re: 440 source 543 [Re: olwhite64] #1929664
10/10/15 04:10 PM
10/10/15 04:10 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I didn't use 440source rods, I run GRP rods. But I used 440source pistons and crank. It runs hi 5's in the 1/8th. It's a 77 440 block with a 1/2 fill and main studs. Indy -1, roller cam and Sequential EFI
Re: 440 source 543 [Re: olwhite64] #1929912
10/10/15 11:44 PM
10/10/15 11:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pro's/Con's?
Cons ... external oil pickup lines because the stroke is too long to clear an internal pickup tube.
Re: 440 source 543 [Re: RapidRobert] #1929916
10/10/15 11:46 PM
10/10/15 11:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If the crank doesn't have the extra wide flange you don't need them , the normal flange fits that block just fine ...
and good luck finding them if they are anything like the low decks ... not made anymore.
Re: 440 source 543 [Re: JohnRR] #1932436
10/15/15 02:42 AM
10/15/15 02:42 AM
Thanks double R, its been on hold for quite awhile but I will check into that & see what I need to do/not do/change. it is a pricey deal & I did already grab a bolt in pickup for external oiling that 'source had on (clearance) sale for dirt cheap (not a big start but every bit helps) & the one guys' post on the cheaper Molnar crank/Mahle pistons deal sounds worth checking into especially since I wont be racing it, just an occaisional street blast
Re: 440 source 543 [Re: olwhite64] #1932657
10/15/15 03:39 PM
10/15/15 03:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Even if you have the wide flange crank ... which I doubt it is ... you can use a narrow flange bearing , it won't hurt a thing.
Re: 440 source 543 [Re: JohnRR] #1933056
10/16/15 03:42 AM
10/16/15 03:42 AM
the block I have is a 74 with the wider flanges. it'd be the 'source kit (their crank). iirc I asked em about the later bearings which were extra. just not sure at the moment if 100 extra cubes is worth a 2K (& then some) $$$ outlay
Re: 440 source 543 [Re: olwhite64] #1933066
10/16/15 06:43 AM
10/16/15 06:43 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You need to consider the difference in costs between the stroker kit, and the parts/machine work required just to reuse your old parts, then the cost of the stroker kit looks alot better. The costs of all the parts have been going up, back when I bought my stroker kits they were under $2K.
Re: 440 source 543 [Re: 451Mopar] #1933091
10/16/15 09:42 AM
10/16/15 09:42 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Woops, guess I had already responded..
Re: 440 source 543 [Re: olwhite64] #1934246
10/18/15 01:17 PM
10/18/15 01:17 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Haven't done a 540 but we have done 3 of the 440 source 512 RB kits. I like everything about it except I wish the rings were a little racier. We are gonna try the stealth heads on the one we are doing now.
2011 Drag Pak Challenger
