Manual 4 speed. Gear oil or ATF? #1928581
10/08/15 08:34 PM
10/08/15 08:34 PM
Pennsylvania
ColorMeGreen Offline OP
Pennsylvania
What is the recommended lube for a 69 A833? I tried a quick search but didn't find it.. I just dumped in Lucas 75/90 but haven't run it yet.
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1928588
10/08/15 08:41 PM
10/08/15 08:41 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1928643
10/08/15 10:06 PM
10/08/15 10:06 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Some say ATF.I have used nothing but 80 90 gear oil since the 60s.My 65 thats well abused and the Express truck still have gear oil and no problems.Ma did recommend ATF in winter if shifts were hard.I drove mine for years year round in the 60s 70s and gear oil was fine.Rocky
Chrysler Firepower
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1928828
10/09/15 02:34 AM
10/09/15 02:34 AM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
90 weight is all I've ever used.
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1928829
10/09/15 02:38 AM
10/09/15 02:38 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I've found straight 90wt to be too thick so I run 80-90 or 85-90. I've never tried ATF.
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1928864
10/09/15 08:34 AM
10/09/15 08:34 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
80-90
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1928926
10/09/15 11:36 AM
10/09/15 11:36 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
ATF is far too thin .....90 wt is all I ever used for 47 years....if atf was fine...they'd put it in rearends also....your tranny works just as hard,if not harder because of shifts....wher/who said ATF ?? crazy...ATF...Automatic Transmission Fluid
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1928949
10/09/15 12:16 PM
10/09/15 12:16 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Actually factory did recommend ATF for cold weather.Ive never used it and probally never will.After close to 45 years on my trans Its fine and shifted great even cold.Rocky
Chrysler Firepower
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1928950
10/09/15 12:16 PM
10/09/15 12:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Castrol syncromesh works well , it designed to be used in transmissions with brass blockers
Re: Manual 4 speed. Gear oil or ATF? [Re: therocks] #1929034
10/09/15 02:31 PM
10/09/15 02:31 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
not debating the point made but I NEVER heard of anyone saying"cold weather is coming,gotta change the tranny fluid".....just wasn't done in my area
Re: Manual 4 speed. Gear oil or ATF? [Re: terzmo] #1929041
10/09/15 02:43 PM
10/09/15 02:43 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Read it all the time back in the early 70's in service manuals.. Also recommended 140 wt for 18 spline 4 speeds.. WAY TOO thick, I tried it.....
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1929152
10/09/15 05:29 PM
10/09/15 05:29 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
recommended and accomplished are two different things
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1929165
10/09/15 05:54 PM
10/09/15 05:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you've ever disassembled an 833 with high miles that ran only ATF you'd find the cluster gear pin will have a groove worn in it from the needle bearings due to the ATF.
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1929168
10/09/15 05:59 PM
10/09/15 05:59 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Always used 90 wt,never any problems.
Nautilus Racing-
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1929227
10/09/15 07:45 PM
10/09/15 07:45 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
I use 80w-90. I topped it off with GL-5 a few years ago and it hasn't dissolved yet.
68 Roadrunner. 383 4-spd. Beat up.
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1929257
10/09/15 08:53 PM
10/09/15 08:53 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Gl-4 for trannys and GL-5 for diffs. There is a difference and it matters way more than the weight. DO NOT use GL-5 in your 833.
Master, again and still
Re: Manual 4 speed. Gear oil or ATF? [Re: ColorMeGreen] #1929302
10/09/15 10:24 PM
10/09/15 10:24 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
They have Sta-Lube 85W-90 GL4 at NAPA and also on Amazon.com. Has been working great for me. I asked Brewer's and they said they would recommend I use this.
http://www.amazon.com/Sta-Lube-SL24239-GL-4-Multi-Purpose-Hypoid/dp/B000M8RYMC
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
